Water pump # DOOE-D
Thanks’ Mike, any idea about the years that pump was used. I'm having a dickens determining the year of the engine I have, it is a 302w.
I’ve researched all the numbers on the engine and nothing seems to jive with what I’m told to look for. I thought I had it pinned down to an 1987.
I need to replace the water pump at it seems to be an early 70’s pump.
Obviously i can just carry the pump in the parts store and get a match but i would still like to figure out the year of the engine.
4F15 = Assembled June (F) 15, 1974 (4).
If marked D0OE-B or C or G = D0OZ-8501-B r/b D6ZZ-8501-B = 302/351W Waterpump.
Thanks Number guy, but the pump is on a 302w in a 1973 f100. I assume this pump was also used on the 302's?
It cannot be on a 302 or 351W if it's marked D0OE-D
"Who goofed? I've got to know!" -Howard Cosell
You gotta look very close at the suffix, as some die stamps were worn, causing C's to appear to be D's and etc.
If it's marked D0OE-B or C or G = 302/351W (see post 4).
Bona fides: 1971 FoMoCo Master Cross Reference Catalog ~ Page 126, Column 2 / 1990 FoMoCo Obsolete-Supercede-Interchange Catalog ~ Volume I, Page 924, Column 2.
Ok gents, heres what I'm working on. Pics of the pump, the engine, and numbers on the engine block. Please enlighten me. Got a bit crossed up on the last post, but as I said originaly DOOE-D 09 below,
That intake shown is a Weiand 8020 Stealth, for a 302. 105302 stamped in the back of the heads.
