67 vs 72 automatic steering column length
Old 01-10-2013, 03:11 PM
sullyda1's Avatar
sullyda1
sullyda1 is offline
I can't remember if I would have changed out the automatic steering column on my 67 F100 when I converted over to power steering 35 years ago. I used the parts from a 72 F250 w/ Ford box. The current steering wheel distance is just fine. Seems there was a length issue, like one was longer than the other.
My reason for asking is I need to change out the lower bearing and find different part numbers between 67 and 72. I am not sure which one I have. Does anyone know if there is a column length difference?
Old 01-10-2013, 04:05 PM
DavidB's Avatar
DavidB
DavidB is offline
When I changed my 70 F100 over to power steering about 13 or 14 years ago, I had to change the steering column in order to mate properly with the gearbox. I actually used an automatic column. Mine was a three speed column shift, since converted to 4 speed floor shift.
Old 01-10-2013, 04:55 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
The power steering gear box is taller than a manual one, therefore the column is shorter.
As such, I'd guess you got the column from the same donor as the steering gear.
Old 01-10-2013, 06:57 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
The column is not shorter for power steering, just the shaft.
Old 01-10-2013, 07:18 PM
sullyda1's Avatar
sullyda1
sullyda1 is offline
Thanks guys, it is all coming back to me now - the taller box required the shorter shaft. I used the guts from the donor but kept my outer tube so I did not have to repaint it.
Been a great truck since 1969 when I bought it from original owner. it is still my daily driver
Old 01-11-2013, 09:08 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
I used the parts from a 72 F250 w/ Ford box.** The current steering wheel distance is just fine. Seems there was a length issue, like one was longer than the other.
Where did you find Ford part numbers/applications that said the lower bearings are different? Not from the '64/72 Ford Truck Parts Catalog, as you can see:
C3DZ-3517-A .. Steering Column Bearing / Available from Ford.
1965/72 F100/250 2WD upper & lower / 1965/70 F100/250 4WD upper / 1967/72 F350 upper & lower.
Bendix P/S: 1966/68 F100/250 2WD / 1969 F100/250 2WD before serial numnber D96,001.
** Ford P/S: 1969 F100/250 2WD & F350 from serial number D96,001 / 1970/79 F100/250 2WD & F350 / 1976 F100 4WD / 1976/79 F150 4WD / 1977 F250 4WD (not a High Boy) & 1978/79 F250 4WD.
Old 01-11-2013, 06:03 PM
sullyda1's Avatar
sullyda1
sullyda1 is offline
Bill, you are absolutely right. I was reading the LMC catalog and with your info I realized I was looking at the part # for the lower column bearing seal. Also with the part # you provided I found that I had a new bearing in my parts supply. Thank you. Your knowledge is invaluable.
Eston Newbern
05-31-2020 09:03 AM
The blue oval
11-06-2013 12:55 PM
FESTUS65
09-29-2011 02:51 AM
allwthrrider
11-22-2010 10:28 PM
Ban_four
09-12-2005 08:04 PM
Quick Reply: 67 vs 72 automatic steering column length
