97' 2.3 into 91' ranger..... crank sens issues - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-10-2013, 12:17 AM
pbarcus pbarcus is offline
pbarcus is starting off with a positive reputation.
Question 97' 2.3 into 91' ranger..... crank sens issues
Hopefully someone out there has the magic answer.
recently i decided i was going to put a motor into my 91 ranger.
bought a 97' 2.3 unaware that the crank sensors would be totally different..
my question is..... can the 97 crank sensor be spliced into and work with my 91 harness??
Old 01-10-2013, 06:52 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
'97 uses EDIS which is a stand alone ignition controller, similar to the DIS system on your old motor. However the signal that EDIS uses is different and incompatible with the one that DIS uses. Without significant changes, there is no way the EDIS setup will work with your existing wiring. You at the very least would need a way to reprogram the stock computer, and even that may be insufficient.
To use a '97 engine, you are goning to need to figure out how to use the old sensors on the new block. This should actually be a fairly straightforward affair. If the mounting bolts are missing, you will need to drill and tap the block to mount the sensor, and you will need the crank pulley off the old motor. If yours uses the cam synchronizer, you will need that too, but in order for it to work, you need a special alignment tool. Basically you will need to swap everything that is different between the motors.
So the next question is, who sold you the motor telling you it was compatible. Any good auto salvage yard can check compatibility.
Old 01-23-2013, 07:56 PM
drb1956 drb1956 is offline
drb1956 is starting off with a positive reputation.
PCM isuues????
Can you go back to the boneyard and get the PCM and ignition module (if so equiped) for "that" engine????
do 97 ford rangers have knock sensors in the 2.3l jarrod27 4 Cylinder Engines 0 10-10-2012 08:14 PM
Newbie 91 Ranger Turbo Indiana Chapter 2 01-31-2005 03:25 PM
crankshaft position sensor question el conquistador Ranger & B-Series 7 06-28-2004 06:48 PM
91 ranger no start pman26 Ranger & B-Series 7 02-28-2004 07:08 PM
91 Ranger S 2.3 Engine fast idle sticks. jmax Ranger & B-Series 4 06-23-2002 12:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
