Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 01-09-2013, 08:02 PM
mixup mixup is offline
Garage is empty, add now
mixup is starting off with a positive reputation.
Brake Pedal Return Spring
On a 60 F100 was there a return spring on the brake pedal? If there was where does it connect?
  #2 (permalink)
Old 01-10-2013, 07:12 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a good reputation on FTE.spurredon has a good reputation on FTE.
Yes there is. There is one on both the brake and the clutch pedal. They both attch. to a bracket that is bolted to the firewall in between the pedals for the lower end of the spring. The upper end of the spring attchs. up near the top of the pedal on the engine side of the pedal bushings. Not a very clear description perhaps. you might want to consider buying a shop manual, available on Ebay and other etc...
  #3 (permalink)
Old 01-10-2013, 10:13 PM
Thanks for the information. I have the bracket on the pedal but I didn't know where the bottom bracket went.
  #4 (permalink)
Old 01-11-2013, 04:53 PM
F-100CustomCabTBC's Avatar
F-100CustomCabTBC F-100CustomCabTBC is offline
1958 Ford F-100
F-100CustomCabTBC is starting off with a positive reputation.
Here's one of the best pictures I have of the bracket and spring.
Click the image to open in full size.
__________________
Blaine, SE MN
'58 F-100 Custom Cab short box, owned since Aug. 2006
  #5 (permalink)
Old 01-11-2013, 06:53 PM
Great picture, Thanks.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
