Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Missouri Chapter
Sign in using an external account
Register Forgot Password?
Missouri Chapter Join Chapter , Leader:tcbofade
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 01-09-2013, 06:39 PM
earthquake68's Avatar
earthquake68 earthquake68 is online now
earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.earthquake68 has a good reputation on FTE.
The C-cab build!
Well, now I'm kicking off the C-cab build. One thing about a one off build, there's not much to look at in the beginning. Since I'm building the whole truck from scratch, you'll just have to be patient with the progress.
I started to fabricate the front suspension. I'm using the front and rear axles from a slick side Ford. A '61 Front axle (right, RC?) and a 9" from a '66 Ford.
Here are the spring perches for the front axle. I'm converting the parallel front leaves in to a transverse leaf like the early Fords had but keeping the '61 axle mounting locations.
Click the image to open in full size.
Here's the perches mounted and the spring sitting in place. I'll make the shackles tomorrow and get the spring mounted. The perches aren't done yet. They need to be tweaked a little more to allow for tad more spring travel. I need to open the radius up about a 1/4" more over all to allow for the spring to flatten out as it flexes. I also need to weld plates on for the radius arms to mount to.
Well here's the whole truck so far! ...at least what I have built of it, anyway.
This is gonna take a while.
__________________
Alan Fenstermaker
'73 F-100 360, 3 on the tree 2WD (Uncle Jesse's truck)
'75 F-250 468, C6 Monster Truck (Earthquake III)
'79 F-200 300-6, 4 spd. 4x4 (Alice)
'79 F-150 400, C6 4x4 (Ka'Bluey)
'94 Dodge 2500 V10, Automatic
Old 01-10-2013, 08:10 AM
garrett_8 garrett_8 is offline
garrett_8 is starting off with a positive reputation.
cant wait to see this build!
Old 01-10-2013, 09:07 AM
cyclopsblown34's Avatar
cyclopsblown34 cyclopsblown34 is offline
cyclopsblown34 has a good reputation on FTE.cyclopsblown34 has a good reputation on FTE.
Dang, you might own a grinder but with welds that look like that, you have no need for the grinder!
__________________
Chip in Russellville, MO
66 Buick Skylark Special convertible...
1975 F250 4x4
.Project overwhelmation...yes I know it is not a real word, but more a feeling. Thanks Rich
Old 01-10-2013, 10:50 AM
Thanks Chip. I'd eventually like to TIG everything together. I have an ugly weld on one of the perches because it was the first bead I put down. The metal was ice cold and I had trouble with penetration. After that, I heated up the metal first and it went a lot better.
__________________
Alan Fenstermaker
Old 01-12-2013, 04:24 PM
I got the shackles done. I also went back and cleaned up the brackets a little. I'm satisfied with these parts so far.
This is a little different from anything I've ever done before. Usually I save up some money, buy a part and bolt it on. Pretty much every part I bolt to this truck will have to fabricated or modified first.
__________________
Alan Fenstermaker
Old 01-12-2013, 05:42 PM
It'll definitely be a one of a kind C-cab and can't nobody else say they built it.
__________________
1975 F250 4x4
Old 01-12-2013, 06:03 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Workaholic
77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of77&79F250 has much to be proud of
I have 2 bronco's frames (one is a little bent in the tail end, lol) and the complete front and rear suspention +axles and a title for the rear ended one....anything you need let me know. Cause you know I have a part or two....LMAO
__________________
77&79 F250 Rich & Penny
77 351M auto, a/c, add a leaf 33x12.50's
78 (79 headlights) 460 4 spd, 4", a/c and 35's
79 351M 4spd 6" Skyjacker Edelbrock-Holley-Hedman 35's
99 Ranger 4x4, 98 Expedition 4x4, 73 Bronco Hillbilly-Bug
71 Bronco 302 35" Boggers 5.58 gears spool/locker
Old 01-13-2013, 11:57 AM
Thanks Rich, but all the parts I need from Ford I already have. Everything else I need will have to be built.
__________________
Alan Fenstermaker
Old 01-23-2013, 09:48 PM
I bought the steel for the chassis. As soon as I get a spot big enough to work on this, I'll start welding up the frame.
__________________
Alan Fenstermaker
Old 04-01-2013, 06:51 PM
I got some more progress on the C-cab today. I started welding up the frame rails.
I welded a brace into the front crossmember so it stays rigid.
I put a 12" kick up in the rear section so I can lower it down. I want around 5" between the ground and the bottom of the frame rails.
Here, it's starting to look like something. I built in plates with the uprights so they had a little more strength.
Here are the frame rails with the front crossmember mocked up. I hope to have a roller by the end of the month.
__________________
Alan Fenstermaker
Old 04-01-2013, 06:56 PM
77&79F250's Avatar
Workaholic
When the day comes and you get some shop floor space you will be down right dangerous.....looking good.
__________________
Old 04-05-2013, 06:38 PM
Today I got the front crossmember and spring mount finished up.
Here's the plate to capture the bottom of the spring.
And everything bolted together.
I made a cool little cover for it to hide the ugly spring mount.
__________________
Alan Fenstermaker
Old 04-05-2013, 07:46 PM
77&79F250's Avatar
Workaholic
Sweet job.... you get the job of welding the new roll cage in the bronco some day.
__________________
Old 04-05-2013, 07:57 PM
I assume by ugly, you're referring to the bolts. The bracket and welds are too nice to cover up.
Old 04-06-2013, 07:44 PM
whiskey runner's Avatar
whiskey runner whiskey runner is offline
whiskey runner is gaining momentum as a positive member of FTE.whiskey runner is gaining momentum as a positive member of FTE.
looking good alan.. should be a interesting build..
__________________
if you cant run with the big dogs...stay on the porch
71 f100 "rip van winkle" been asleep for 25 years
300-6 npt435.. 20mpg avg. took many years to get that patina just right
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
1966 F150 build earthquake68 Missouri Chapter 300 08-06-2014 07:53 AM
The next project earthquake68 1973 - 1979 F-100 & Larger F-Series Trucks 6 07-04-2012 04:39 PM
Earthquake Build thread ....slow but sure. earthquake68 1973 - 1979 F-100 & Larger F-Series Trucks 15 05-27-2012 09:30 PM
Oh boy, what I did today! I may be in trouble. earthquake68 1973 - 1979 F-100 & Larger F-Series Trucks 25 02-02-2012 08:20 PM
How fast can you take a running truck and stack it up in the yard? earthquake68 1987 - 1996 F150 & Larger F-Series Trucks 26 12-30-2011 02:28 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
