Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-09-2013, 06:22 PM
Teager Teager is offline
Garage is empty, add now
Teager is starting off with a positive reputation.
2008 Expedition Fluid Change Intervals
I have 5.4 4x4 and the dealer says I should change the tranny fluid every 30k and the axle/differential and transfer case fluids every 60k. They did not say anything about tranny filters though. This tranny does not have a dip stick like all others I have had. Does anyone know how or where to check the tranny fluid level and condition ? Any suggestions if these intervals are excessive or if anyone has even changed the axle/differential and transfer case fluids ?
  #2 (permalink)
Old 01-10-2013, 03:45 PM
fstaslp fstaslp is offline
fstaslp is starting off with a positive reputation.
When I tried at the dealer, they said my 07 never needs to be changed. Obviously I am going to change it myself once it gets warmer. any one have a how-to on that?
  #3 (permalink)
Old 01-10-2013, 07:09 PM
Beechkid Beechkid is offline
Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.
Here's what I have done on every vehicle (auto trans) that I have owned for 30 years....
At 20k miles, I change the filter (due to possible residual/initial wear particulates that may be floating inside) and either drain the torque converter (if so equipped with a plug) or disconnect the trans cooler line at the radiator, fill the pan with fresh fluid, my wife starts the engine and when 2-3 quarts drain into a bucket, she shuts it off, I refill the pan and repeat until the fluid is clear and in case of the f150, 14 quarts of fresh fluid is in.
I change only the fluid after that (unless I determine substances/contamination in the oil). The intervals vary depending on the type of trans, type of fluid and conditions, but in general, every 30k miles. Heat is a killer on automatic trans fluid and when we lived in the desert area, I changed the trans fluid at the end of summer every year.
In regards to filters, oem is fine, but I typically use Wix.
In regards to trans oil, both in sticks and autos I have always used Valvoline.
I have also never had a trans failure in any vehicle I own and typically keep my vehicles for 10+ years, with over 100k on the odometer.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
