Swapping a 460 into a 79 f250 4x4 - Ford Truck Enthusiasts Forums
Old 01-09-2013, 04:29 PM
big ole ford big ole ford is offline
big ole ford is starting off with a positive reputation.
I am thinking about replacing the 351m in my 79 f250 four wheel drive with a 460 from a 71 continental. So what i have so far is the complete engine with all the accesories, a non-weighted flywheel for the early 460, a new clutch kit ,a heavy duty starter and a rear sump oil pan. So what i need to know is what mounts i need to install the engine in the truck, i bought frame mounts at the junkyard and new motor mounts from the parts store and then realized that the 2 wheel drive and 4 wheel drive frame mounts are totally different as in the 4x4 there is no crossmember to bolt the mount to.Im quite sure that someone has done this before and knows the correct mounts i need and anything else i need to make the swap.Thanks for all your help
Old 01-09-2013, 05:03 PM
olered79f250 olered79f250 is offline
olered79f250 is starting off with a positive reputation.
I just got this swap done and all I can say is quit thinking about it and do it. Get the l&l motor mounts. I tried to make things work and when it was done I just bought the l&l stuff. If I had a welder and some torches I could have done more but I'm really happy with all the l&l stuff.
Old 01-09-2013, 05:57 PM
JB78f150's Avatar
JB78f150 JB78f150 is offline
JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.JB78f150 has a good reputation on FTE.
Old 01-09-2013, 06:16 PM
Quote:
Which mounts from L&L did you get?
Old 01-09-2013, 07:09 PM
lafermedavid lafermedavid is offline
lafermedavid is gaining momentum as a positive member of FTE.lafermedavid is gaining momentum as a positive member of FTE.
l&l
Conversion Kit #9B
1977-79 F250/F350 4WD Trucks equipped with 351M/400 engines and standard transmissions T-18 and NP435 converting to 429/460 engines. l&l you didnt mention your tranny setup l&l sells all gear seperate as well as a kit,,,,Jeffs bronco Graveyard also sell l&l componets
Old 01-09-2013, 07:40 PM
I had the 351m with a c6. I was just going to get the parts I needed but ended up buying them all and at different times. I should've got the kit but I tried to get by the cheap way. Just a roofer with his old truck and money is tight, lol. I didn't know l&l had more than one mount for this swap have about an inch thick piece of rubber and have a lifetime warranty. If you have a pan already you might want to buy them individually.
Old 01-09-2013, 09:09 PM
Quote:
Originally Posted by lafermedavid View Post
Conversion Kit #9B
Guess i could have included this to begin with it has a np435 tranny and a np203 transfer case attached to a351m or a 400 i dunno which one it is probably a 351m judging by the severe lack of power
Old 01-12-2013, 08:51 AM
PACrewCab's Avatar
PACrewCab PACrewCab is offline
PACrewCab is starting off with a positive reputation.
I got mine from Transdapt but L&L looks to be the same. Very easy, no headache!
Old 01-12-2013, 10:41 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE F-250 WARHORSE is offline
F-250 WARHORSE is gaining momentum as a positive member of FTE.F-250 WARHORSE is gaining momentum as a positive member of FTE.
I have used the L&L mounts before. They fit nicely and the engine sits right. My problem is they break easily and then I have to relace them. L&L only warrants them if you run their conversion headers. otherwise warranty is null and void. I am seriously thinking about those severe duty mount at JBG. They look awesome, and not that much more than L&L, but remember that your 460 is going to be way north of 300 hp from a 71 lincoln, 10.5:1 CR and like 365 HP and 500 tq according to chilton specs. That is a lot for L&L mounts. Goodluck.
Old 01-12-2013, 10:52 AM
bertha66's Avatar
bertha66 bertha66 is offline
bertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud ofbertha66 has much to be proud of
When I got my 76 F250 4x4 the 429 was already in the truck, kind of. It was a hack job with turn buckels holding from exhaust manifold to the frame. And the engine pertches on the frame had been cut out where the mount bolted to them.
We drilled and fitted 390 mounts to the 429 block. Then cut the face off off the engine pertches and refaced them using steel from a leaf spring. Lowered the 429 and the trans. into the truck and marked where the new mounts would set. Lifted the engine out and put the pertchs back out and cut new slots for the mounting studs. then reintalled the engine and trans. Total cost was less than $20.
Old 01-12-2013, 11:22 AM
Blackfoot Big Block Blackfoot Big Block is offline
Blackfoot Big Block is starting off with a positive reputation.
Quote:
Originally Posted by F-250 WARHORSE View Post
... but remember that your 460 is going to be way north of 300 hp from a 71 lincoln, 10.5:1 CR and like 365 HP and 500 tq according to chilton specs
Don't forget in 1971 the reported horsepower numbers were SAE (Society of Automotive Engineers) Gross Horsepower.
In 1972 they changed to SAE Net Horsepower. There's quite a difference in the methodology. Gross basically allows open headers, few belt driven accessories and ideal conditions. Net requires production exhaust manifolds with all emissions equipment as well as production air cleaner and belt driven accessories.
The SAE Net Horsepower ratings give a truer representation of actual power.
Old 01-12-2013, 11:27 AM
motor mounts
Ok WARHORSE,how do you think the West Coast Bronco engine mounts would allow that motor to sit vrs the l&l and the l&l headers,,Im in this dilema as well 1971 Lincoln 460
Old 01-15-2013, 03:42 AM
twisted84toyota twisted84toyota is offline
twisted84toyota is starting off with a positive reputation.
I got solid mounts off ebay for 40 bux and been running them 4 years now with no issues ever!!
I also have mad dog fender well headers and the fit and finish was unbelievable!!!
i'm running a 72 lincoln motor
Old 01-15-2013, 06:49 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by big ole ford View Post
I am thinking about replacing the 351m in my 79 f250 four wheel drive with a 460 from a 1971 Continental.
Even if you personally pulled the engine, there's no guarantee you got a 460, due to swapped engines.
Make sure by measuring the stroke that it is a 460, as the block casting number: D1VE-6015-AB applies to 1971/73 429 & 1971/78 and some 1979 460's.
During the 'Horse Power Race" automakers vastly overestimated their HP figures. While rated at 365 gross HP, 1971 Lincoln/Continental Mark III 460 is roughly 275 net HP.
1977 4.9 six to 460 engine Steven Gatley Sr Engine Swaps 11 12-27-2014 01:05 AM
351 to 460 swap Granny Gear 1973 - 1979 F-100 & Larger F-Series Trucks 16 06-24-2012 08:25 PM
79 driveline swap maltese22 1973 - 1979 F-100 & Larger F-Series Trucks 14 06-03-2012 11:57 AM
79 f250 4x4 chassis mounts/rear shock mount cszeman 1973 - 1979 F-100 & Larger F-Series Trucks 11 07-19-2008 04:25 PM
460 swap info mositso 1973 - 1979 F-100 & Larger F-Series Trucks 5 09-03-2004 01:05 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
