2000 Ford Ranger 3.0 v6 missing - Ford Truck Enthusiasts Forums
Old 01-08-2013, 11:37 PM
Klindsey1990 Klindsey1990 is offline
Klindsey1990 is starting off with a positive reputation.
Hi folks, I'm new to this so forgive me if I don't give enough info. I've been having problems with my Ranger misfiring. It had blown the headgasket about a year and a half ago and I had it replaced. I now have around 126,000 miles on it and just before Christmas it started developing a miss. I put fuel injector cleaner in it, which seemed to help slightly but it came right back as I was driving home that night. It blew the number 3 plug out of the motor the next day, never had that happen before, ha. Anyway, me and my dad have changed plugs, plug wires, and coil pack, still the same problem. I don't want to keep pouring money into it and it doesn't fix the problem. It misses at an idle and the motor shakes. It runs, and it misses from the 50-65 mph range. If anyone has had this problem or ideas I would greatly appreciate it. Thanks!
Old 01-09-2013, 12:52 AM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
Do you have any codes ? try to narrow it down to the missing cyl. Ck for proper fire , bad injector , burnt valve ,wiring issue ,ect . Do a compresson test to ck . cyl. health .
Old 01-15-2013, 02:28 PM
Quote:
I had a diagnostic check on it today. Cylinder 3 and 5 were misfiring along with throttle control sensor bad. Replaced sensor and had computer reset. I've changed the plugs and wires about 6 months ago. Maybe got a bad set of plugs or wires??
Old 01-15-2013, 08:22 PM
JWC 3's Avatar
Do you still have the miss ? if you only changed the tps , you probably do . Ck #3 and #5 plug . Also ck coil , plugs, and wires for carbon tracking . It does have one coil ,I think . #3 and #5 paired ? one can cause a code for both . Ck coil for cracks . Cracks will leak voltage and cause misfire . If not ignition look at fuel and compression .
Old 01-16-2013, 02:38 PM
Got the miss. changed 3 and 5 plugs and wires. So far so good.
Old 01-16-2013, 07:08 PM
JWC 3's Avatar
Good luck , hope you got it !
95 Ranger 2.3 L low speed acceleration miss and hesitation perryg114 Ranger & B-Series 15 02-07-2016 09:54 AM
Bad Miss Misfire1981 Modular V8 (4.6L, 5.4L) 4 04-24-2015 08:59 AM
Random miss at full throttle haroldrussi Ranger & B-Series 8 12-03-2014 05:14 PM
Need some serious help, engine missing, loud crackle 2500 mile drive ahead 90pioneer 1999 - 2003 7.3L Power Stroke Diesel 9 05-19-2013 08:57 AM
2.3 missing when accelerating ? Don't know what to do? shark1979 Ranger & B-Series 11 11-17-2012 08:48 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
