Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Crossovers
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
  #1 (permalink)
Old 01-08-2013, 04:06 PM
dothedew192 dothedew192 is offline
Garage is empty, add now
dothedew192 is starting off with a positive reputation.
2010 All Wheel Drive Ford Flex, Only front tires turning?
Hey guys, i'm usually cruising the 7.3 diesel side of this forum but today i stopped in to this part of the forum because i need your guys advice. Today we had a 2010 ford flex 3.5 come in, which is suppose to be All Wheel Drive is only front wheel drive, a good customer reffered these guys to us hoping we could tell them it's not the transfer case, or PTU as ford has told me it's called in these. There is no grinding or anything whatsoever, but you can put it up on the lift and turn the rear driveshaft and the rear wheels will turn, it will just not do it off of the engines power. I know there is an actuator in the vehicle, but i do not know what voltage or ohm too look for to tell if it is bad. Can you guys help me out with this issue at all? I sincerely appreciate you guys reading this thread and any help you can give.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
