Trade my 1988 f350 for your diesel parts !
I'm looking for the parts to convert my c6 diesel truck to a ZF 5
G
Here's the deal you trade me a good not worn out zf5 diesel bolt pattern 4x2 tranny , clutch set , flywheel , crossmember , mounting hardware , clutch hydraulic parts , and clutch pedal assembly - everything needed for a swap and I give you :
1988 ford f350 4x2 cab and chassis 161" wheel base truck
460 efi
3.55 rear gears
Zf5
11' utility body all doors close and lock
This is a running and driving truck
Currently registered in Connecticut
Many new parts ; brakes , ball joints , fuel pumps/ sending units , shocks , exhaust , heater core , parking brake cable, distributor , rear hub seals , turn signal switch , clutch master cyl , brake master cylinder , rear brake hose
New gaskets on top end ( jasper rebuilt engine )
Needs a weindshild - crack
Pm me for more details - pictures .
Yes I have the title in my hand
Yes I'm serious .
Thanks , Jon
G
460 efi
3.55 rear gears
Zf5
Yes I'm serious .
Thanks , Jon
Holy, Crap I wish I wasn't all the way in California. I have a 4wd setup but it's an entire running truck with the dana 60 front. Has injection issues though. If you still have it and have a means to cover the country cheap, drop me a line...
Still have it but Cali is a bit far lol
crestfallinman
08-25-2013 03:54 PM
redman84
05-17-2010 09:40 PM
propaneman
05-31-2009 04:41 AM
