Front Rotor question about my '85
I want to replace my rotors but seem to be finding conflicting information on if they are integral rotor/hub or separate. I wanted to order the parts before I tear them apart.
For the separate rotors, do they bolt to the back side of the hub, or fit over the outside of the hub.
There appears to be a joint between the hub and rotor, so I think I have separate rotor/hub, but I can't tell for sure. I'm including a couple of photos in hopes they'll help to answer. I checked and do have dual piston calipers, if that matters.
Thanks.
Here's a closeup. There looks to be a joint right at the little indentation.
Thanks.
If you go to Autozone's site and look your truck up, it shows two different stud sizes, and you can get it with the hub or without. Take it all apart, and drive the studs out, and it should come apart. Even at autozone's site, the one that comes with the hub says it's "pressed in" with "pressed in" studs.
Rockauto is the same way; You can buy it with the hub and rotor together, or take yours apart and buy just the rotor.
I just did this on my truck. You can drive the studs out with a hammer. They are swaged into the rotor/hub from the back. You can hammer them back into your new rotor, but you should check the rotor for straightness because hammering on it can warp it. If it does, you'll have to get your new rotor turned. I ended up taking mine so a shop to have the studs pressed back in to avoid this problem.
Now I just have to decide if I want to rebuild or replace the calipers. I'm replacing the MC and a couple of brake lines plus the flexible lines, probably installing a manually adjustable proportioning valve and completely replacing the rear brake components.
If your pads are worn down pretty thin, I would replace the calipers, or get ready to just in case. It's common for the pistons to build up rust behind them over time, and when you press them back into the caliper to install the new thicker pads, it gets pushed over the rust and it will then soon stick.
Also pay careful attention to the caliper slides where the caliper mounts. The caliper only has pistons on one side. So for the other pad on the other side to apply itself to the rotor, the caliper itself has to move in it's mount. They can get stuck from corrosion over time, so this area needs to be cleaned up, and greased with high temp grease or never seize. You can tell if this was a problem on the old pads, if one is worn thinner than the other.
dfronek
01-26-2011 05:13 PM
threefiftyone
08-30-2004 05:27 PM
