Who's lowered? - Ford Truck Enthusiasts Forums
Who's lowered?
Old 01-08-2013, 11:58 AM
nick5446 nick5446 is offline
nick5446 is starting off with a positive reputation.
Who's lowered?
I've been reading into lowering my '58 LWB and it seems cheap and easy enough. I've modified suspensions and chassis on a bunch of vehicles in the past, but I don't have any experience with these specifically. I think if I do it I'll reverse my rear mounts and replace the springs (one is real saggy and the other pack has a broken leaf) and use these replacements from John's F100 (https://secure25.securewebsession.co...shop/index.htm).
What are the cons of going down about 4" all around? If I keep manual steering is there anything that needs to be modified? How badly will payload suffer? This is what I'm most concerned about since I actually use my truck as a truck. I won't be carrying 5,000 pounds of concrete, but I will probably have 700-1000 pounds of motorcycles back there from time to time...will I be bottoming out with every pebble I hit? What if I get some heavy duty springs (do they exist?) and use those with my reversed mounts?
Anything else to look out for?
Thanks in advance!
Old 01-11-2013, 02:43 PM
I should also add that I'm willing to notch the frame in the rear, but obviously I'd prefer not to.
Old 01-11-2013, 07:59 PM
fast58's Avatar
fast58 fast58 is offline
fast58 is starting off with a positive reputation.
Many questions you have. Unfortunately I cannot help you too much.
I can tell you that I did the axle flip kit on my '92 F-150 in the past and every time I went over a bump the rubber stops on the frame hit the axle and bounced the back of the truck up. (bottomed out)
I would expect similar results with a '58.
Old 01-14-2013, 12:54 PM
I appreciate the input. I'm gonna put out a few feelers about the steering, but looking at it it seems like it will be ok. As for the rear, I think I'm just gonna go for it and if it's an issue I'll put it back to stock or notch the frame.
Old 01-14-2013, 03:55 PM
iggy.ho iggy.ho is offline
iggy.ho is starting off with a positive reputation.
Hi, If you don't notch the frame, you will never be able to carry more than a box of feathers and you will still bottom out. Also, you won't be able to get the front end low enough, even with a dropped axle. The a&s end will be a lot lower than the front, looks kinda funny. Of course you could go for an independent front suspension! How much money do want to spend??
Old 01-14-2013, 03:58 PM
Quote:
As little as possible, always!
My plan was to reverse the rear spring mount (getting 4-5") and then using the monoleaf reversed eyelet front springs from John's F100 for about $475
Old 01-14-2013, 06:56 PM
fast58's Avatar
For ~$500 you can get the Crown Victoria Independent Front Suspension and you will be much happier with that than you ever will with lowering shackles or lowering axles or what ever other lowering modifications you will spend money on.
There are plenty of threads on here about putting this CV IFS in our model trucks and it is pretty straight forward. I did this swap and I am very happy with it.
Old 01-14-2013, 07:25 PM
hobbs53's Avatar
hobbs53 hobbs53 is offline
hobbs53 is starting off with a positive reputation.
i dropped my '59 3", and the front hits the rubber stops when i hit a pretty good bump. i too plan on putting the bike in the back; haven't yet, but don't know if i'd drop it any more than 3". all things considered, i would probably look at the cv ifs if i had to do it over.....
Old 01-15-2013, 10:36 AM
Quote:
That's disappointing, but good information, thank you. What do you run for shocks/springs?
Old 01-15-2013, 10:37 AM
Yeah, I'm weighing it. To be honest I'm less concerned about the front bottoming out than the rear. It also looks like my truck will be down for a long time if I do the CV IFS swap versus a few hours to swap spring packs.
Old 01-15-2013, 05:06 PM
vntgtrk's Avatar
vntgtrk vntgtrk is offline
vntgtrk is starting off with a positive reputation.
Makes me wonder what I'll run into. I went with revers eye main leafs front and rear for around a 2" drop. I plan on using load leveler shocks in the rear from Monroe so I can still carry heavy stuff like my girlfr/ I mean lumber, etc.
Old 01-15-2013, 05:13 PM
Quote:
Let me know how you do, I'm curious to know
Suspension differences bewteen Limited v.s. other trucks? the_auto_tech 2009 - 2014 F150 7 11-14-2015 09:46 AM
MII Front end coil spring question Tyler S 1948 - 1956 F1, F100 & Larger F-Series Trucks 43 02-25-2014 03:05 PM
Comprehensive "Steering Wander" Thread Compilation Stewart_H Excursion - King of SUVs 112 01-28-2014 05:27 PM
68 f-100 project--Cool Goodies from Portland Swap meet Must-Truck 1967 - 1972 F-100 & Larger F-Series Trucks 4 04-16-2012 11:44 PM
Options for wheels...8 lug x 6.5 bolt pattern BlueOvalBud Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 10-03-2011 01:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
