Catalytic Converter 2007 F150 - Ford Truck Enthusiasts Forums
Old 01-08-2013, 12:54 PM
dewey47 dewey47 is offline
dewey47 is starting off with a positive reputation.
Have a 2007 F150 5.4 V8, the CEL was on and the repair shop said I needed to replace both catalytic converters and the down stream O2 sensors about $1700 including labor, I said not now. I drove about 60 miles and the light went out, it has done this before, never flashed or anything just stays on. Truck runs fine but has 198,260 miles, does this sound like a converter problem?
Old 01-08-2013, 01:37 PM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
Welcome to FTE dewey47,
We canʻt say that it IS a cat problem without you posting the actual codes.
At nearly 200,000 miles (if not a typo), what could be in question are
the O2 sensors.
Also, we donʻt know how the truck was cared for over the past 6 years.
When was the last tune up. plugs, cops, filters, etc.
Posting more information from you will aid in a COMPUTER SCREEN diagnosis.
Old 01-08-2013, 01:56 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
No- I would R&R the O2 sensors as their life span is typically 100k miles
Old 01-10-2013, 12:28 PM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Quote:
Don't take it back to that shop. You always replace upstream sensors when you replace a cat. You would only ever replace the downstream ones if you had a code indicating they were bad.
I would start with replacing the upstream O2 sensors, they are way overdue for replacement.
What about your other tune up items? Make certain you are up to speed on all maintenance items outlined in your owners manual. If you are overdue, get it done. Also run a carbon treatment through your intake, carbon deposits can cause cat problems, and/or contribute to inaccurate sensor readings.
Old 01-11-2013, 11:31 AM
Thanks, I had coils 8-3-7-2 replaced Sept 2012 and the plugs and wires replaced Oct 2012 at Ford dealer, the CEL didn't come on until 30 days or so after the plugs and wires were changed. Runs fine no miss even at max acceleration, any ideas on what brand of carbon treatment?
Old 02-06-2013, 03:06 PM
Seafoam is my personal favorite, BG44k is a good one too. Moot point though if you have bad O2 sensors. I would start with those, they are way overdue.
02 sensor bypass xxstroker_acexx 2004 - 2008 F150 0 05-26-2014 11:12 PM
Will Lacquer thinner really clean my catalytic converter? bharris42 2004 - 2008 F150 7 09-07-2013 05:18 PM
catalytic converter question bkpackerfan Exhaust Systems 9 06-15-2013 07:13 PM
Catalytic Converter Rattle 01371406 1997 - 2003 F150 5 02-22-2011 06:25 PM
Rattling catalytic converter BlueOvalFitter 2004 - 2008 F150 10 04-19-2008 10:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
