Mercon V vs. Mercon III - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 01-08-2013, 07:36 AM
AmmoDawg AmmoDawg is offline
AmmoDawg is starting off with a positive reputation.
Anyone know the difference between MERCON V, MERCON III, and MERCON? I've got a '05 EB Expedition, 5.4L V8 with a 4R70/75E transmission (that's what's listed in the owners manual). This is what the manual says:
"Some transmission fluids may be labeled as dual usage, such as MERCON and MERCON V. These dual usage fluids are not to be used in an automatic transmission that requires use of the MERCON type fluid. However, these dual usage fluids may be used in transmissions that require the MERCON V type fluid.
MERCON and MERCON V type fluids are not interchangeable. DO NOT mix MERCON and MERCON V. Use of a transmission fluid that indicates dual usage (MERCON and MERCON V) in an automatic transmission application requiring MERCON may cause transmission damage. Use of any fluid other than the recommended fluid may cause transmission damage."
If I'm reading this correctly, it looks like I CANNOT use MERCON V (maybe MERCON III as well...) in an automatic trans that requires regular MERCON but I should be able to use a dual usage fluid in a trans that calls for MERCON V, correct?
I'm in S. Korea and asked the post car care center if they carried MERCON V. They looked in their system and said MERCON III is what was listed...I don't really trust them but I'm kind of limited on choices. I would have to try to special order the MERCON V if I can't get it through a local Korean dealer.
Thanks!
Old 01-08-2013, 07:45 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Since there's no such thing as "MERC III", that narrows it down.
Ford discontinued Mercon back around 97.
Everything uses Mercon V now that used to use Mercon, regardless of the recommendations made at the time the vehicle was made.
If your vehicle was made to use Mercon and that's all you can get, then it wont hurt anything to continue using a Mercon-rated fluid - you just won't get the benefits of the improved fluid.
Old 01-08-2013, 10:26 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Mercon V is synthetic, any other Mercon is not.
[Transmission] C6 w/4WD Paul Sheahan 1973 - 1979 F-100 & Larger F-Series Trucks 9 10-30-2016 07:05 PM
Mercon/Dexron III vs. Mercon V.... EMC V10 X 1999 to 2016 Super Duty 11 01-21-2011 10:59 AM
What type of fluid to use in 4R70W Fordenthusiasts 1987 - 1996 F150 & Larger F-Series Trucks 8 10-25-2010 07:06 PM
Mercon V or Mercon SP 60RatRod 1999 - 2003 7.3L Power Stroke Diesel 7 12-06-2008 07:15 PM
Bye Bye Mercon/DextronIII Hello Merc V ccerniglia Oil & Lubrication 18 10-17-2008 11:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
