Rear drums not keeping adjustment...I have to re-adjust every 1000 miles.
I have an 89 f350 4x4 dually and my drum brakes seem to basically back off the adjusters by them selves. I adjust them and it stops great for a while and then it starts to slowly deteriorate until i have no rear brakes.
I have done this 4 times now so I am sure its actually backing of and its not just worn out.
Is there some sort of auto matic adjuster that is not working or something? I have herd of something that tightens when you back up, but I am not experienced with drums.
As others have mentioned, take the drums off and make sure that the adjusters are operating correctly and on the correct wheels. If you pull on the adjusting cable and release it should advance the adjuster one or two clicks. With the drums and wheels back on, and everything working properly, you can also adjust the brakes by slamming on the brakes in reverse.
Get a close adjustment with the star wheel. Then to finish the adjustment, carefully back up in reverse and get up to about 10 MPH than slam on the brakes and let the truck come to a complete stop before releasing the pedal. Do this several times and your brakes should self-adust to the proper position. They will not over adjust if working properly.
FourdoorF350
Escape & Escape Hybrid
18
08-18-2013 07:06 AM
Toma
05-04-2007 03:07 PM
cjben
10-30-2005 12:43 AM
