Slow down the delay wipers?
Old 01-07-2013, 05:22 PM
damarble's Avatar
damarble
damarble is offline
My 90 at least has the delay option instead of just hi/lo but even the delay is much too fast for my needs. Any way of slowing it down further?
Old 01-07-2013, 06:12 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
You might look into adapting a newer model system, I can't recall right now but it should be an easy project, unless there is anything related with the wiring I haven't considered.
Old 01-07-2013, 06:48 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
Wiper motor speed is motor speed, there's no changing that.
If you want to change the delay between sweeps there is likely a potentiometer you can adjust, or a resistor you could swap on the control board inside the F0TF-17C476-AA governor assembly.
Old 01-08-2013, 11:11 AM
damarble's Avatar
damarble
damarble is offline
Sounds like a potentiometer might do it.
At the slowest setting it's not too bad but about 2x that delay would be perfect. I've gotten to where I just flick the **** on an off at my own pace but that's bound to wear it out prematurely and isn't really convenient either.
Old 01-08-2013, 11:42 AM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
It sounds to me like there may be some components of the governor that are not the values they once were. (thinking bad capacitors here) It's just an electronic delay circuit afterall.
You might try swapping in another governor. Get a cheap one from the junk yard and see if the interval changes, before you spend big bucks on a new unit.
I'm just thinking out loud here, so no guarantees... I know that when mine is on the slowest setting, I wonder if mine are EVER going to swipe again!
wiredgeorge
06-17-2019 03:12 PM
alpar80
17
09-02-2013 05:10 PM
Tony_C
01-20-2012 12:10 AM
matt2491
03-09-2008 01:30 PM
PROSTOCK
01-21-2006 11:58 AM
Quick Reply: Slow down the delay wipers?
