Trailer wiring colors stock from truck side?? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-07-2013, 02:54 PM
1fixitman's Avatar
1fixitman 1fixitman is offline
1fixitman has a very good reputation on FTE.1fixitman has a very good reputation on FTE.1fixitman has a very good reputation on FTE.
Early 1999 7.3L Manual transmission 2WD ODOMETER is in sig. and not applicable to this discussion any way.
I have some wires that I need to identify from the stock trailer harness that all had been cut by the previous owner. Some have wire nuts on them. I would like to wire in a 7 pin connector. I can always use an adapter to go to a 6 pin if needed. I already have a 4 pin connector that utilizes the brake/running/reverse light plug. It plugs into each plug OEM style and has a beautiful 4 pin connector that comes out of it. The white wire for that connector has a ring terminal connector that is connected to ground because its ground is not on that harness. I am cleaning up the hack job that used to be a old 4 pin connector and an old 6 pin connector. Please identify the following wires so I can make a good 7 pin connection and or good use of these wires.
The tailer wires were all cut off except for the red wire from the old 6 pin connector. It was connected to the small brown w/white stripe wire on the stock harness. The wires from the stock trailer harness are taped into a separate bundle from the standard truck brake/running/reverse lighting bundle. Three of the wires are much larger guage than the other 4 wires. I will capitalize the LARGER ONES to set them apart. Please Advise and thank you for helping.
BLUE
ORANGE
WHITE
black w/light green stripe
yellow
dark green
Old 01-07-2013, 06:17 PM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
WHITE is ground on pin #1
Black/Light Green is trailer back-up lights on center pin (not used very often)
ORANGE is trailer battery charge on pin #4
BLUE is trailer brake controller current on pin #2
Yellow is left turn on pin #5
dark green is right turn on pin #6
Brown/White is running lights on pin #3
Old 01-07-2013, 10:02 PM
1fixitman's Avatar
Thank you. I am going to find a 7 pin connector tomorrow to wire this up.
Making a stand alone EFI harness (pics) NotEnoughTrucks2014 Engine Swaps 10 02-17-2017 11:05 PM
2006 F250 Trailer Running lights No Power to 7 Pin Trailer Connector tgossell 1999 to 2016 Super Duty 0 10-30-2016 01:27 PM
7 Pin Trailer Connector 1L243 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 21 02-03-2015 03:52 PM
Factory Wire Harness Pin Out 728Winston Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 8 03-27-2014 06:12 AM
1995 Hd F250 Trailer Harness? 54 Oldsman Electrical Systems/Wiring 4 04-06-2003 01:09 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
