Ford 240 in a '60
Old 01-04-2013, 03:31 PM
retrosixty6's Avatar
retrosixty6
retrosixty6 is offline
Ford 240 in a '60
Hey y'all does anyone know if a 240 will fit up to the factory 3 on the tree bellhousing? If not then will the t98 bellhousing and trans fit in the truck without (much) work? We found out the cylinder heads for the 292 are cracked. We might get replacements later on down the line but for now we are just looking to get the truck driving again.
Old 01-04-2013, 03:49 PM
f5fordgirl's Avatar
f5fordgirl
f5fordgirl is offline
If you use a 240, nothing from the 292 will bolt up. You'll need the 240 bellhousing, same as small block v8 from 65 up, you'll have to make mounts and add a trans crosmember, different driveshaft but it can be done.
Old 01-04-2013, 10:22 PM
hiball3985's Avatar
hiball3985
hiball3985 is offline
I don't think you'll be happy with a 240. If you want a later model six go with the 300.
Old 01-04-2013, 10:26 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,592 Likes on 1,297 Posts
Find a 300 with a trans on it, 3, 4 or 5er. The trans to bell pattern changed somewhere in there to a rectangular or "butterfly" pattern from the old "square" pattern that your T98 has.
Old 01-05-2013, 10:37 AM
retrosixty6
I already have a 240 with a bellhousing and 4spd out of my '66 rust bucket and that engine runs, so we might just fab up some mounts and use that til we get the y-block rebuilt.
Old 01-05-2013, 01:40 PM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
Nothing wrong with using what you have, that's the true spirit of hot rodding. What are you planning to do for clutch linkage? Modify the original slave cylinder to actuate the clutch?
Old 01-05-2013, 01:48 PM
hiball3985's Avatar
hiball3985
With all the things that will need to be changed and then change again for the Yblock can't you just wait to instal the Yblock or do you need to have it on the road now?
Old 01-06-2013, 04:54 PM
retrosixty6
Honestly my pops and younger brother are the owners of the truck so its really up to them, I'm just looking to gather some information for them. And I'm not really sure about the clutch linkage, any tips if we do decide to put in the six?
Old 01-06-2013, 05:26 PM
hiball3985's Avatar
hiball3985
you are trying to mix apples and oranges as they say. There is no easy way around it that I know of .
Old 01-06-2013, 08:36 PM
willowbilly3
There are some small block Fords in the 80s with external slave hydraulic clutches, a bell housing from one of them might be the easiest.
Old 01-07-2013, 08:55 AM
retrosixty6
Well thanks for the help guys I guess we'll just keep the six for a later project or something. Like I said I have no real opinion on what to do with this truck I'm just trying to gather information and it looks like it wouldn't be the best idea.
Old 01-07-2013, 06:32 PM
willowbilly3
You might look into a later V8 swap. You can get front and rear cross members for most popular swaps.
Old 01-07-2013, 09:27 PM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Some have even re-powered with a diesel.......There's lots of good ones out there.
Brian Piper
09-12-2014 03:35 PM
hivoltj
08-23-2012 10:00 PM
mark72newk
06-27-2006 07:51 PM
Herman
09-07-2004 06:24 AM
58Model
11-15-2000 11:43 AM
Quick Reply: Ford 240 in a '60
