Edge Insight and Torque App
I downloaded Torque App and bought also the Bluetooth adapter. Got it all set up and ran it.
I found, for those with Edge Insight Juice W / Attitude, that the signal to the EDGE for the PID being monitored by Torque App is intercepted and will not read on the Edge Display.
I normally monitor EGT, EOT, EGT, and Boost. There is a problem with the EOT reading, and I have seen a thread or two on fixing that equation. Boost, ECT, and EGT showed Zero on the Edge Display, but were correctly displayed on the Torque App.
The Torque App with the Powerstroke Profile provides several points to monitor that the Edge does not. Specifically three seperate FICM voltage points.
The FICM was the last unknown for me. Having reflowed components in it as a preventative measure and taking/finding acceptable voltages at the time, beyond that I did not know the status of my FICM. I loaded those PIDs including battery voltage and was happy to see 12.5-13.0 being supplied and 48 VDC from the FICM.
I did this on my Driod Bionic / Android Op Sys and all worked well except the EOT. I would be happy to leave the Dongle and App running all of the time but the display provided by the phone is too small and I will be looking into a tablet or something close to that to make reading multiple gauges at the same time possible.
If you are on the fence about getting this handy tool, I believe it well worth the investment. I spent about $30.00 total. And the tool allows me to check any vehicle, which I tested on a freinds Dakota. He had an engine light that turned out to be caused by a small emissions leak.
The included software for the dongle allows you to upload software to a Laptop or CPU to perform diagnostic checks on vehicles 1996 and newer and is easy to use.
Eric
Eric
This is how I have the Oil Temp setup on mine and it works just fine. Under "Manage Custom OBD2 PIDs" find the one that reads "Engine Oil Temp"... (I spelled this one out because when you add the gauge make sure to choose "Engine Oil Temp" and not "Engine Oil Temperature" .. I did this...lol and it doesn't work). These are the settings I use (some of them are the default so don't bother changing them if you have the same settings):
OBD2 Mode and PID = 221310
Short name=EOT --- you can call this one anything you want.
Min Value = 0.0
Max Value= 300.0
Scale Factor=x1
Unit Type=°F
Equation=((((A*256)+B)/100)-40)*(9/5)+32
OBD Header to use= ---I leave this one Blank.
Min Value = 0.0
Max Value= 300.0
Scale Factor=x1
Unit Type=°F
Eric
Eric
Min Value = 0.0
Max Value= 300.0
Scale Factor=x1
Unit Type=*F
Min Value = 0.0
Max Value= 300.0
Scale Factor=x1
Unit Type=*F
do not leave in the degree symbol....
Give it a shot...
Can someone in here help me? Whenever I try to change the equation on my phone it it says equation invalid. Can SOMEONE PLEASE tell me why this keeps happening? I am extremely frustrated here. My eot only reads 32 degrees. I have added the ford / powerstroke preset PID's. Please help!
Thanks in advance
05 F250 6.0 powerstroke, just in case it makes a difference.
Thanks in advance
Thanks in advance
Thanks in advance
Enter the equation for EOT exactly as I have it a few posts up. If you are getting the "equatio n invalid" error you need to carefully check the equation... something is entered wrong... the usual culprit is the parenthesis (((()))). No worries though I think we all have received that error...lol.
Turn on Torque APP
Go to "settings"
Go to 'manage extra IDs/Sensors'
find 'engine oil temp'
touch it.
touch 'edit'
this is what you will see:
221310
short name: EOT
MIN- 0.0
MAX- 300.0
SCALE- x1
Unit type- C yes, C
Equation: enter this one, it's easier and works: (((A*256)+B)/100)-40
OBD header- Auto
Now exit and go set up a gauge.
when it gives you the list to choose your gauge scroll down to "engine oil temp"
Do not use "Engine oil Temperature"
Now you should be able to read EOT.
And now that you are in this, need to fix trans temp.
Follow the same steps, but when you get down to the OBD Header, make sure it is changed to TCM.
Then when you go to select the gauge you want make sure you select "Transmission Fluid Temp" NOT THE OTHER ONES!!!
Go to "settings"
touch it.
touch 'edit'
221310
short name: EOT
MIN- 0.0
MAX- 300.0
SCALE- x1
Unit type- C yes, C
OBD header- Auto
