You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
OK, I am finally taking out my truck project that has been sitting in my garage for a year. It is a small window cab F100 and I want to know if there is a way to make it into a big window cab. The guy I bought it from gave me extra roof with back window part of cab. I have found a Ch**y site that shows out to make the replacement, but nothing for Ford. Can it be done??? or do I just stick with my small window cab? I hope this made sense. Thanks for any info.
Yes it can be done. There was an article back in classic trucks a number of years ago that converted a 57-60 cab to big back window. Are you going to do it or have a body shop do it? If a body shop I would be very choosy as to who does it so it doesn't come up mal-aligned.
It is the same principle if it is Ford or Chevy.(that probably opened a can of worms) The main concern I would have is to make sure you brace the cab. Weld in braces before you cut anything. I would also keep the doors on so the cab does not shift. That way you can check and double check to make sure it's still lined up!
Another thing to consider the time and money involved in doing a conversion. Maybe just get another rust free cab? It just depends the shape of your cab. And how far are you going with the truck. A full resto? And also do you have tools and garage space to do it. Just some things to take into consideration.
Iv'e been kicking the big window upgrade idea around for my 59 F100 also. If I do this, I would do the whole roof and entire back of cab so the only welding would be at the top of the front window pillars and the back of the floor pan, under the fuel tank. Does this sound reasonable? My floor pan and firewall are in good shape with no major holes, but my roof is rotted above the front window and the back of the cab has holes in the bottom corners so that's the basis of my idea.
__________________
Chet
1959 F100 4X4 Custom Cab Styleside
2003 F250 4X4 Extra Cab Short Bed
2005 Excursion limited 4X4 6.0L
Reason: typo
Yeah I I'm pretty sure those whole rear cab panels separate at factory seams to make easy work of it...
I did this about 15 years ago but had to use the bottom of the small window car. I cut the roof of the big window below the window opening and through the windshield posts. Would have been much easier if I could have used the complete back and if I had a wire feed at the time. Still worked out pretty good. Just remember to brace the part on the frame so it will stay in place. Hardest part for me was getting started. Just take plenty of measurements and don't get in a hurry. Good luck.
