My build thread - Ford Truck Enthusiasts Forums
My build thread
Old 01-06-2013, 11:20 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
My build thread
A woodworker by trade, this is my first total frame off build. I can tell you that the help available on FTE has enabled me to get as far as I have. Thanks to all here for all the posts that show how it is done, and for all the feedback when I ask things that seem simple to the ones who know.
Here are some pictures of the work I have done in the last year or so.
Cross member welded in, frame stripped and painted, TCI front coil overs installed, gas tank and Explorer rear installed with the new CPP springs and spring mount kit, cab gas filler hole filled and cab primed, cab painted, and cab mounted with new mounts. About 8 months, a little at a time.
Old 01-06-2013, 11:42 PM
topmoo's Avatar
The PO had some really bad work in this truck, like a motor mount that was just a flat piece of 1/4" steel bolted directly to the frame and to the SBC with no vibration dampers at all, and the trans crossmember was another piece of metal that had one bolt in the tail of the trans and the metal was just sitting on the frame rails, not welded or bolted. He also had covered over the rust holes and the seams in the two piece front fenders with a half inch of bondo and fiberglass. I really couldn't afford to change the motor and trans so it still has the sbc in it - but I ended up having to rebuild the motor and changing the th350 to a 700R4 (overdrive). I did some woodwork in trade for having the engine rebuilt and getting the transmission from a friend who has one of the best car repair shops in town.
Here are a few more pics:
Old 01-06-2013, 11:50 PM
topmoo's Avatar
Running boards repaired with some metal patches and some fiberglass with bed liner. And my attempt at getting the hood straight. I worked on this for 4 days! Amazing how many small dents and dings in this hood. You can still see some. I also had to weld a few patches underneath on the edges where there were stress cracks. The PO took the nose trim off when he painted and broke three of the 4 bolts off of it. He had one bolt and some liquid nails holding it on. I am going to have to weld new studs on and test my welding skills.
Old 01-07-2013, 08:58 AM
perks56's Avatar
perks56 perks56 is offline
perks56 is starting off with a positive reputation.
Great job, looking really good.
Kevin
Old 01-07-2013, 09:04 AM
r_reed's Avatar
r_reed r_reed is offline
r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.
very nice looking build. you will have a very nice truck when it's done.
Old 01-07-2013, 09:31 AM
fatfenders's Avatar
fatfenders fatfenders is offline
fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.fatfenders has a good reputation on FTE.
Looks like you are doing a nice job. And though it may not seem like it, your rate of progress is well above average too.
I loved the part about the Liquid Nails. We have all been victimized by the P.O. in one way or another. My front clip assembly was installed with four 3/8 bolts and a nice stack of washers.
Old 01-07-2013, 09:34 AM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Topper,
It looks great! Is the two tone blue/black the final color scheme?
You have been busy - My hood took forever as well - It's still hitting in one small place up front. Have you tried installing it back on the truck - they didn't make adjusting the hood a simple process.
That engine looks great - very nice.
Ben in Austin
1950 F1
Old 01-07-2013, 10:34 AM
Project-55's Avatar
Project-55 Project-55 is offline
Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.Project-55 has a great reputation on FTE.
Your making great progress and its looking good to.
In referance to the hood, we thought it would be a no brainer to plop the hood for Jon's 50 back on but NOOO. It took us like 5 times of putting it on, taking it off and tweaking it a bit then bolting it back up before it, finally fit, really glad that it over.
I really hope your hood fits better than Jon's did, I wouldn't wish that hassle on anyone.
Old 01-07-2013, 07:33 PM
tinman52's Avatar
tinman52 tinman52 is online now
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Looking good, great color too!
I have a '52 nose trim piece you can have if you want....IF I can find it LOL.
Old 01-08-2013, 08:56 PM
johnny2stroke's Avatar
johnny2stroke johnny2stroke is offline
johnny2stroke is starting off with a positive reputation.
Nice truck! I have a couple questions: in the picture of the backside front fenders did you use the weather strip to fill a gap? If so good idea, I have a set of 51 glass fenders for mine from bebop and I have some gaps on either side. Also where is your column from and how long is it?
Old 01-08-2013, 09:55 PM
topmoo's Avatar
Quote:
The column is a 30" Ididit. The weather strip is actually from LMC made to fit there. Ross (ALBUQ F1) had to tell me about it after I posted a thread about how the Bebop fenders just didn't fit well from the cowl down to the running board. With the rubber it looks great.
Ben, the fenders came black from Bebops and I kind of like it. Who knows, I might end up painting them black. But I do have lots of the "burn out blue" from Eastwood still...
Thanks for all the kind comments from all, it has been a real learning experience for me so far with a long way to go still.
Old 01-08-2013, 09:57 PM
topmoo's Avatar
I haven't even tried to put the hood on yet. I really hope it fits!
Old 01-08-2013, 10:10 PM
topmoo's Avatar
That would be great if you do find it. Let me know and if I have anything you can use...
Old 01-08-2013, 11:31 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
So is your build thread like mine started? I did not get my build thread going in the beginning. and I had to try and reassemble the process in my head and post it here. I guess your avatar makes me think you already had most of this done.
Nice stuff here though!!! Looks great!!
Old 01-09-2013, 02:25 PM
topmoo's Avatar
I just did the build thread a week ago, luckily I had some pictures and could somewhat reconstruct what I have done. Now that I finally started this build thread, I plan to post the highlights of the boring details.
I hope to get mine to look almost as good as your someday.
Early Vs Late 2004 Front spring hanger vlietracer64 1999 to 2016 Super Duty 6 01-18-2016 09:17 PM
Undercoating and frame rust green_95 1994.5 - 1997 7.3L Power Stroke Diesel 1 01-12-2016 04:58 PM
92'-96' SC frame/running gear under 77' SC abosely 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-12-2015 08:55 PM
88' F350 CC DRW frame question abosely 1987 - 1996 F150 & Larger F-Series Trucks 3 12-03-2015 07:56 AM
lots of progress on 51 f1 Gwilkrrs 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 04-03-2015 08:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
