2000 Ford Excursion Cruise Control Problems? - Ford Truck Enthusiasts Forums
Old 01-06-2013, 08:56 PM
Mitchell_Texas Mitchell_Texas is offline
Mitchell_Texas is starting off with a positive reputation.
Hey, having the usual problems with the cruise control. 100k miles on the Ford Excursion. Cruise control stopped working. I took it into the local "stealer." They wanted to charge me 650.00 to fix it. Is this the Cruise control servo or is there an even more expensive part to fix the cruise control?
Old 01-07-2013, 05:43 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
It's certainly possible for the speed control servo to go bad, but there are other things that could cause it as well.
There was a recall campaign for these model years that involved the speed control deactivation switch that is mounted on the brake master cylinder. The recall required that dealers inspect the switch to determine if there was a leak. If the switch wasn't leaking(mine apparently wasn't) they were to install a fused jumper harness inline between the connector and the switch.
But if the switch was in fact leaking the repair was to replace the switch with this part:
Motorcraft SW-6350 Speed Sensor Switch Repair Kit : Amazon.com : Automotive Motorcraft SW-6350 Speed Sensor Switch Repair Kit : Amazon.com : Automotive
And also install the fused jumper harness ensuring to put dielectric grease on the contacts.
So when my speed control wasn't working when I bought my X I unplugged the harness from the sensor on the master cylinder. The inside was wet with brake fluid which confirmed that the deactivation switch had failed, and so I replaced it with the part from Amazon.com and it's worked ever since.
If your sensor isn't leaking then you could follow the instructions in the following TSB for diagnosis:
06-8-5***SPEED CONTROL DIAGNOSTICS - W/O SCP
Old 01-07-2013, 05:54 AM
Tom's Avatar
And lastly if it is the cruise control servo you can buy one for around $320 plus shipping from one of our site sponsors:
2000 FORD EXCURSION Parts - Tousley Ford Parts Depot
They have about the best prices around if you can wait for the part to be shipped to you.
Old 01-07-2013, 01:43 PM
1 Excursion camper's Avatar
1 Excursion camper 1 Excursion camper is offline
1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of1 Excursion camper has much to be proud of
Probably just the switch. had the same thing happen to mine. replaced the switch and all was good. if you unplug the switch you will probably find brake fluid in it. which is why they issued the recall wiring harness for the switch.
Old 01-07-2013, 02:24 PM
Eric H's Avatar
Eric H Eric H is offline
Eric H has a good reputation on FTE.Eric H has a good reputation on FTE.
I did the switch on mine as well. Fixed it in 20 minutes... that included clean up time after I got all the brake fluid off my hands.
Old 07-15-2013, 11:57 AM
Wayne Cameron Wayne Cameron is offline
Wayne Cameron is starting off with a positive reputation.
I ran the Self test Diagnostics and did not get a light on RESUME, COAST, or SET/ACC.
What does this mean????? When I try to use the Cruise control, the "Cruise" light comes on but it does not hold the speed. It just decelerates. Anyone have an answer. Could it just be a switch on the master cylinder?
Old 07-15-2013, 01:57 PM
Eric H's Avatar
Seeing how the switch on the master cylinder is one of the most common failures I would start there. Look for any leaking brake fluid and ensure the electrical connections are tight and clean.
Old 07-15-2013, 03:33 PM
More info on Cruise Control
I just took the vehicle out on the road. engaged the Cruise control. The Cruise light came on but again the vehicle just did not keep the speed. I then hit the brake peddle and the cruise light went off as it should. That tells me the switch on the master cylinder is working. The Off button and the On button on the wheel seem to work while the three on the right side don't. RESUME, SET SPEED, COAST. While doing the Seft Test Diagnostic thos three button gave no response while OFF AND ON did blink the "cruise light" once. Still at a loss......thanks for the response.
Old 07-15-2013, 04:24 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Quote:
Where in Texas are you located?
You could be right near me and I could help you pin point the issue.
Between my know-how and the AE scantool, it'll get sorted.
Old 07-16-2013, 11:50 AM
You sent this to me. I am in Buffalo, NY......I'm Wayne. Any ideas about my posts? You seem like you know what is going on. I would appreciate anything you can suggest after reading my posts.
Wayne
Excursion 2000
V10
Old 07-16-2013, 01:35 PM
Replacing switches on Excursion Steering wheel
Can anyone tell me how to remove the air bag cover to replace or check the cruise control switches on the steering wheel of my 2000 Excursion. Is there a danger of the air bag going off????
Old 07-21-2013, 12:00 PM
HELP!!!!!!!
I need you expert advice.....Can seem to get it from anyone. When doing the Self test on my Cruise control Everything works fine until I do the three buttons on the right side of the wheel. There is no response (Blinks) for these. I believe my brake switch is Ok as putting on the brake turns off the Cruise Light....Do you think it might be bad switches or a Speed control servo? Any help would be greatly appreciated.
Wayne
PS: See my previous posts under Cruise Control Problems.
Old 07-25-2013, 12:15 PM
Still looking for a reply
I am still awaiting a reply to my problem. When doing the self test on my Excursion The Off button and the On button on the wheel seem to work while the three on the right side don't. RESUME, SET SPEED, COAST. While doing the Self Test Diagnostic those three button gave no response while OFF AND ON did blink the "cruise light" once. Still at a loss......Where can I find out what it means when the three buttons have no response to the Test? I know the buttons on the right side work because they light the "cruise" light when the set button is pressed while driving. HELP!
Old 07-25-2013, 02:18 PM
Sorry I some how missed the replies for this thread...
If you look right below the resevoir, you should see a small sensor attached. This sensor detects when you step on the brakes and disables the cruise control. When this switch either fails or is unplugged, the cruise control will not work.
This is it: http://www.oreillyauto.com/site/c/de...1967&ppt=C0039
Old 07-25-2013, 04:07 PM
mgraveman mgraveman is offline
mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.mgraveman has a good reputation on FTE.
I am guessing it's the switch on the wheel or the clock spring from the OP's description above.
Cruise Control Not Working Eric H Excursion - King of SUVs 16 03-28-2016 06:47 PM
Cruise Control Not Working rock2610d Excursion - King of SUVs 4 09-28-2015 11:17 PM
Cruise control heads up!! Mr. PC 2004 - 2008 F150 2 05-27-2015 02:24 PM
Cruise Control wm knight New Member Introductions 0 04-06-2015 10:06 PM
2003 Excursion V10 Cruise Not Working Dealer Stumped Codyskato Excursion - King of SUVs 16 04-26-2014 11:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
