CD Stuck in 6 Disk CD Changer
I took the cover off and watched the CD unit work. The problem is when you put the CD in the unit it should grab the CD and load it to the desired location. It does not grab it, you must push it in the entire way. Once loaded it will play. When you hit eject it gets set in the location to eject but nothing pushes it out. So the problem is the load and unload.
Any ideas? Does anyone refurbish them? I didn't see any gear problems or jammed labels. It seems to be component failure.
Thanks!
Thanks!
Thanks!
Thanks!
smoore79
10-22-2008 02:32 PM
djhuebner
08-02-2005 09:34 AM
j.steinmetz
08-19-2003 05:17 PM
teederj2002
08-16-2003 02:24 PM
