flooding - Ford Truck Enthusiasts Forums
flooding
Old 01-06-2013, 04:05 PM
BIGDOG7283 BIGDOG7283 is offline
BIGDOG7283 is starting off with a positive reputation.
flooding
I have 1987 ford bronco with a 5.0 cold starts great and runs perfect but when i shut it off and try to restart it it floods the motor and if i let it set for a half hr it will start but have to pump the heck out of the gas pedal but will start perfect if cold
Old 01-06-2013, 04:08 PM
Need help fast daily driver to work don't like driving my new truck work is very greasy
Old 01-06-2013, 04:12 PM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
Is it EFI or carbbed now?
Old 01-06-2013, 04:46 PM
Efi its stock
Old 01-06-2013, 05:04 PM
khadma's Avatar
Carpenter Local 745
Is the CEL on?
What is the general condition and maintenance of the truck, mileage,
Etc.? How long has this condition existed?
Old 01-06-2013, 05:05 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Is the Check Engine Light (CEL) on? Even if it is not, have you checked for codes?
How old are the plugs/wires/cap/rotor and filters?
Old 01-06-2013, 05:07 PM
khadma's Avatar
Carpenter Local 745
We think alike
I'd like to add battery condition too.
Old 01-06-2013, 06:50 PM
it has 134000 complete tune up two weeks ago new coil module cap and all battery is new bought less then a month ago ran great till two days started it up ran to the store and came back out wouldnt start like it was flooded could smell the gas i let it sit for a half hr and i tried it and it tried to start so i pumped the hell out of it and it started let sit for two hrs after i got home started perfect
Old 01-06-2013, 06:56 PM
The check engine light isn't on and i tried to get the codes checked but where its older they said they couldn't check them
rla2005's Avatar
Quote:
Punctuation would to decode what all that means. Somewhere in there I think you state you replaced the Ignition Control Module (ICM)?
Old 01-06-2013, 06:59 PM
rla2005's Avatar
Fuel Injection Technical Library How To Run a Self-Test
or purchase one of these: Equus 3145 Ford Digital Code Reader : Amazon.com : Automotive
Old 01-06-2013, 07:15 PM
ICM is new
Old 01-06-2013, 08:48 PM
rla2005's Avatar
ICM is new
Now we are getting somewhere. Did you use thermal grease with the new ICM? This is not the same as dielectric grease.
Why did you replace the original ICM?
Your old one should have been a gray colored Push-Start style version. Is the new one the same or the incorrect black color CCD style ICM?
When the truck will not run/start have you checked for spark?
Old 01-06-2013, 09:23 PM
Yes thermal grease its the gray one and i replaced it bc it went out and it has spark and gas going to the motor i checked the fuel pressure it is getting between 36 and 40 psi when you turn the key on but it acts just like its flooded when you try to start it after its warm if you let it sit for a hr or so it starts fine and i pulled the spark plug while it was warm they were gassed up so i know its flooding i just wanted to know if anyone has had this problem and could help narrow down the list for me
Old 01-06-2013, 10:48 PM
rla2005's Avatar
Many on this forum have experienced a similar problem. It's a process of testing and elimination. I am trying to narrow down the list for you. None of us are standing next to you or have knowledge of what was previously replaced and why. Too many times we have seen someone ignore the basics and start throwing parts at a problem only to find out it was not necessary. Or worse yet introduce a new problem.
You stated "i pulled the spark plug while it was warm they were gassed up" Did you check for spark when the engine is warm? Perhaps the plugs are gas fouled because there is no spark?
flooding 61 uni 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 10-13-2012 08:42 PM
'Clear Flood' option? High Binder 6.0L Power Stroke Diesel 11 05-21-2011 11:17 AM
Flooding Problems 79F250inline 1973 - 1979 F-100 & Larger F-Series Trucks 8 02-17-2011 08:21 PM
flooding issues in morning Nbender74 1987 - 1996 F150 & Larger F-Series Trucks 7 12-16-2008 04:28 PM
1994 F-150 Flooding problems willr3u 1987 - 1996 F150 & Larger F-Series Trucks 2 05-01-2006 04:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
