front wheel hub assembly - Ford Truck Enthusiasts Forums
Old 01-06-2013, 11:33 AM
tfdcapt tfdcapt is offline
tfdcapt is starting off with a positive reputation.
2001 Ford F350 4x4 single rear wheel needs front wheel bearings replaced. I have been told that these trucks have sealed bearing in the front hub assemble ant that I have to buy the whole hub. Is that true and if so where is the best place to get hubs. Thanks for the help
Old 01-06-2013, 12:04 PM
rare_f8 rare_f8 is offline
rare_f8 is gaining momentum as a positive member of FTE.
It's true.
Autozone sells them for fair coin at $184 each, Timken brand, 515020 (This fits late 99 to 2002)
Old 01-06-2013, 01:03 PM
Nicmike's Avatar
Nicmike Nicmike is online now
Proud Sheepdog
Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.Nicmike has a spectacular reputation.
Yep. I just consulted the 2001 SD bible on this, and it says the whole hub must be replaced if the bearings fail. I would only buy reputable brand name part on the hub.
Old 01-06-2013, 01:29 PM
srteach srteach is offline
srteach is gaining momentum as a positive member of FTE.srteach is gaining momentum as a positive member of FTE.
I have purchased 2 units for my 2001 SD from rockauto.com. Best total prices I can find, even with shipping costs. I bought Timkin brand with ABS sensor. The bearing units are not designed to be serviced, no matter who makes them.
I recommend buying the ones with the ABS sensor even if you don't have ABS. You can then remove the sensor and grease the bearing. If you do, there is a fitting you can buy from Riff Raff Diesel: Front ABS Grease-able Block Off Fitting that will let you service these non-serviceable bearings. I bought two of these fittings, even though they are only temporary use for me. I put them in, grease the bearings and take the fittings out.
The wheel studs are changeable, so if the ones on your truck are still useable, you can get the lesser cost bearing unit. That is what I did.
Old 01-06-2013, 01:44 PM
bdpotts's Avatar
bdpotts bdpotts is offline
bdpotts has a very good reputation on FTE.bdpotts has a very good reputation on FTE.bdpotts has a very good reputation on FTE.
i replaced both of my front ones. the entire hub gets replaced. my advice would be to find an extra set of hands... it'll go faster.
Old 01-06-2013, 03:32 PM
HH60FE's Avatar
HH60FE HH60FE is offline
HH60FE has a very good reputation on FTE.HH60FE has a very good reputation on FTE.HH60FE has a very good reputation on FTE.
One more thing. These hubs DONT come with the 4 hub studs. You'll have to remove them from the old units or get new ones, prolly just from Ford. Thats all.
Old 01-06-2013, 04:04 PM
Kdr358's Avatar
Kdr358 Kdr358 is offline
Kdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to beholdKdr358 is a splendid one to behold
I bought moog units that came with studs and the new Yellow O ring. Probably not the best move on my part but Im trusting its still a quality part.
Old 01-06-2013, 04:07 PM
Nicmike's Avatar
Proud Sheepdog
Moog is not what they used to be....starting to source parts from China.
Old 01-06-2013, 05:25 PM
HH60FE's Avatar
Hmmm, I'm gettin ready to order Moog ball joints.
Old 01-06-2013, 05:32 PM
The Timkin ones I purchased came with yellow oring, ABS sensor, mounting studs and wheel studs. I guess the brand is what will determine what comes with it.
Old 01-06-2013, 06:11 PM
Thanks for all the info. Will look into getting timkin parts and doing the job myself instead of going to stealers hip. You guys on this website are great. I have saved a lot of money using info from here
Old 01-06-2013, 06:17 PM
Firefighter 1406's Avatar
Firefighter 1406 Firefighter 1406 is offline
Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.Firefighter 1406 has a very good reputation on FTE.
Also went with Timken from autozone at $184 a piece. 3 yr warranty. They aren't bad at all to replace. And they even came with new bolt studs where every other brand I have bought you had to swap them over from the old hub. Easy change. I say 30 min per side with out air tools. Or maybe I have replaced these way to many times. Count on a hour per side for the first time.
Old 01-06-2013, 08:59 PM
Poolguy601 Poolguy601 is offline
Poolguy601 is gaining momentum as a positive member of FTE.
Quote:
Did you need a puller to remove the hub and bearings?
Old 01-06-2013, 09:18 PM
Nope. Remove the wheel, brakes, and front locking hubs. Snap ring and thrust washers behind locking hub and the 4 nuts behind where the front ujoints is and you are good to go. Should pull right out.
Old 01-06-2013, 09:19 PM
Quote:
No. Bolts on the back of the bearing next to the axle shaft are what keeps the bearing attached, not friction.
  1. remove brake cylinder and disc
  2. take the 4x4 hub off,
  3. remove snap ring and two other spacers (remember how they are positioned)
  4. remove ABS sensor (if you have one)
  5. remove 4 nuts next to the axle shaft
  6. pull bearing off
2012 wheel hub bearing fishbones182 6.2L V8 4 11-28-2016 04:33 PM
Hubs hubs, roll call for 4wd hub parts HiZ Excursion - King of SUVs 5 01-12-2016 12:47 PM
Abs junction box RDockery 1997-2006 Expedition & Navigator 1 07-26-2015 08:07 AM
front hub assembly rburri 1999 to 2016 Super Duty 6 10-31-2011 09:44 PM
2001 F250 4x4 Front Wheel Hubs and Axles lalevant 1999 to 2016 Super Duty 18 06-12-2009 11:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
