Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 01-06-2013, 10:44 AM
PaulsEdge PaulsEdge is offline
Garage is empty, add now
PaulsEdge is starting off with a positive reputation.
Propane Conversion on my Edge - 6 month report
Hello again, this past summer I asked a few questions on this forum about converting my 2009 Ford Edge SEL CUV (V6 3.5L fuel injected) to run on dual propane/gas and I got some good input, so I decided to go for it, take the plunge and get the conversion done.
Half a year later, I can say with all honesty that it was one of the smartest investments I have ever made!
The engine always starts out running on gasoline (my gas system is still original OEM and the tank was never touched), and then when the sensors decide that the engine has reached optimum temperature, a relay clicks, followed by an audible beep, and other than that, you would never know that the vehicle is now running on straight propane!
I had two 40 gallon tanks installed in the trunk, where the spare tire used to be. They built me a new "floor" for the trunk out of plywood covered with carpet which sits on top of the tanks, and raises the floor of the trunk about 5 inches up from it's original height, but I still have most of my trunk space, even when I throw the spare tire on top of the new floor.
Even though I have 80L of propane tanks, most days it will fill up with 100+ Liters of propane when I run the tanks dry. At the current cost of gas in the Toronto area, it costs me about $122 to fill up with gasoline, and about $48 to fill up with the same amount of propane!!! I get my propane from the same shop that did the conversion for around $0.48 per Liter!!!! That's a savings of about $74 per tank fill up = WOW.
The gauge they install with the propane conversion isn't very accurate at all. It consists of 4 blue LEDs which goes to 3 then 2 then 1 then a red LED lights up when the tank is almost done, then when the propane runs out, it will beep a bunch of times, and then the Propane indicator LED turns off, and I'm automatically back to running on gasoline. I don't bother anymore with this gauge - I just re-set my odometer every time I fill up with Propane, and I know that I get 500km out of it (usually about 520km if I drive easy, and 480km if I stomp on the gas a lot).
I did a road trip up north this past summer, starting out with the Propane, and then using gas, and I was literally able to drive 1000km before I had to start thinking about re-fuelling. I was able to find another Propane station in NorthBay Ont, where they charged $0.79 per Liter of Propane, which still beat the gas prices of $1.35 so the total fuel cost for this trip was cut dramatically thanks to my conversion.
People were telling me I'd lose power with the Propane, and to a very small extent they are right. The response to the gas pedal is (very) slightly slower than gasoline. I have no problem passing someone on the highway, or going up a steep hill at all, it's just slightly more peppy on gasoline. The average person driving my car would never notice the difference, but since I drive the car day in/out, it is detectable to me. That being said, if I really need the full power of gasoline for whatever reason, it's just one tap of a button on my dash, a beep sounds, and I'm on gasoline again, so it's never been an issue for me.
My Edge is navy blue, so I had them install a black propane cover cap in the rear bumper on the left side. Other than the mandatory black diamond "Propane" sticker on the right side of the license plate, you would never know the car was on propane. Most of the cabs in the area use a bright yellow cover cap which sticks out like a sore thumb. I later installed a trailer hitch around the propane system without a problem.
The only other con that I was told about was that my heads would burn out with time (3 years or so), but the shop which did the conversion told me that this doesn't apply to fuel injected newer technology conversions, and I have to wait a few years before I can confirm or deny this, but so far everything is going great, and I would highly recommend this to anyone who is sick of paying ridiculous prices for gasoline! Every time I hear on the news that gas is going up again, or someone complains to me in conversation about their last gas bill, I get a big grin across my face to sum it up in three short words, I'M LOVING IT!
Paul
  #2 (permalink)
Old 01-07-2013, 08:46 AM
gasman6674's Avatar
gasman6674 gasman6674 is offline
1996 Ford F-350
gasman6674 is starting off with a positive reputation.
Good Feedback I am glad its working well for you. What system did the shop use? Also pictures would be nice.
Regards
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
  #3 (permalink)
Old 01-07-2013, 10:32 PM
4wydnr 4wydnr is offline
4wydnr is starting off with a positive reputation.
I'm glad to hear it is working out for you. I'm looking into a propane conversion for my next truck so I'm excited to see your report.
__________________
2001 F-250 7.3L Ext. Cab, SB 4X4
1977 F-250 4x4 5.9L Cummins, Nv4500
  #4 (permalink)
Old 01-07-2013, 11:15 PM
crop harvester crop harvester is offline
crop harvester is gaining momentum as a positive member of FTE.
any figures when the fuel savings will pay for the conversion?
__________________
01 F350 PSD LARIAT CC SB SRW 4X4 4R100 215K 373 GEARS,265/75R16 TOYO OPEN COUNTRY,HUTCH&HARPOON,PREPUMP FUEL FILTER,4" EXHAUST,AIS, PARTS ON BENCH FRX,HPX,CCV,COOLANT FILTER.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
