96 f150 motor swap help! stuck!
okay im at a stand still in the motor swap the donor motor is from a 99 explorer into my 96 f150 theres alot of wires and stuff that i dont know what it is and i cant find anywhere for it on the intake so i need to know whats what... if its emissions stuff and if the truck will run okay without it then ill just leave it off... btw its a mass air truck..
and this 043_zps6a307fa2.jpg photo by Logan_Keeney | Photobucket
conanski, is it a major downgrade? and rla i already have CEL on from egr because i dont have any cats or smog stuff.. im trying to basically get rid of the emissions stuff because i dont need it here.. and i have more than on pic on that link so check em all and see if you know what the other stuff is
Just because your area doesn't require it doesn't mean you don't need it. The computer is designed to operate with ALL those controls in place. If it's a '96 it's OBD-II and you WILL get a CEL and really crappy fuel economy. The computer will never come out of 'limp' mode and it will never read the O2 sensors for the fuel trim process. It will run on a set of static variables in the computer to make sure it will run to get it to the shop.
