Weird RPM's, and gauge readings
So I swapped out my factory steering wheel for a prettier Grant walnut one. During the swap I ended up pulling the 30 amp fuse for the horn, and accidently pulled the 15 amp fuse next to it, (i put this right back in, and am not sure what it is for as I left the truck at home today) This morning I went out and started the truck to "preheat" the cab about 20 minutes before I left. When I took off I noticed the oil pressure was all the way on 'H', the tach wasn't responding, and I had no reading on the voltmeter. In addition the engine kept jumping from about 1000-1500 rpms (not really sure, just going by ear) when I was driving down the road. Needless to say, after about 4 blocks I turned around and parked it.
I have a 4.9
What did I do, and how can I fix it?
I have a 4.9
first I would try a reset. Ford's reset i believe is turning everything in the cab off (climate controls off, fan on lo, lights off, etc.) and turn the key from off to on 5 or 10 times. Every manufacturer has a reset you can do. This one im not fully sure on, this one might be chevy or pontiac. But it might do something. What fuse was it? you said 15 amp, do you still have your panel that gives you a map out of the fuses?
I'd say perhaps you put the fuse in the wrong place. Using a 15A fuse in place of a 10A won't cause this to happen unless the 15A fuse was already blown.
Make sure to put the 15A one back where it belongs, and more importantly don't use it on a circuit that's only designed for 10A.
choate
06-24-2015 10:37 PM
f1fordguy
07-19-2006 04:09 PM
kooper909
07-09-2006 09:51 AM
