Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-05-2013, 06:33 PM
jeffrey2 jeffrey2 is offline
Garage is empty, add now
jeffrey2 is starting off with a positive reputation.
Brake Light Switch Location?
Okay, I know I'm not the smartest out there, but I also know i'm not the dummest.
My wife's Nav won't shift out of park easily, and when following her, i noticed her brake lites don't always lite up...classic switch issue.
I bought a new switch, but cannot figure out where the old one is, does anybody know where the brake light switch is on these cars?
Thanks!
  #2 (permalink)
Old 01-05-2013, 06:34 PM
07 Nav if that helps any
  #3 (permalink)
Old 01-05-2013, 08:14 PM
JWC 3's Avatar
JWC 3 JWC 3 is online now
JWC 3 has a good reputation on FTE.JWC 3 has a good reputation on FTE.JWC 3 has a good reputation on FTE.
Follow the brake peddle assy up . If it has adj. peddles it will be diffrent . Look for the actuator for the booster under the dash . It should be visable from there .
  #4 (permalink)
Old 01-05-2013, 08:15 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
Should be mounted to the brake pedal assembly bracket, I believe it has a plug with 4 wires going to it.
Careful when replacing it.
Removal
1.Disconnect the stoplamp switch electrical connector.
2.NOTE: The stoplamp switch will be difficult to remove if the switch plunger is not depressed. A slight rearward force should be adequate to depress the plunger.
With a light force (approximately 1-4 N [1-3 lb]), pull rearward on the brake pedal, rotate the stoplamp switch 45 degrees clockwise and remove the stoplamp switch.
Installation
CAUTION: It is very important to not press, pull or touch the brake pedal assembly during the installation of the stoplamp switch. Failure to follow these instructions may damage the stoplamp switch.
1.Without movement to the brake pedal assembly, install the stoplamp switch and rotate 45 degrees counterclockwise.
2.Connect the stoplamp switch electrical connector.
Matt
  #5 (permalink)
Old 01-06-2013, 03:49 PM
Where is it?
Am I that blind? I can't see where it is?
  #6 (permalink)
Old 01-06-2013, 06:29 PM
RI-Matt's Avatar
Follow the brake pedal up under the dash, where it connects to the adjustable pedal bracket, look just to the left of it, there will be grayish plug with a white wiring harness that has 4 wires going to it.
Can't miss it.
See photo.
Click the image to open in full size.
Matt
  #7 (permalink)
Old 01-06-2013, 06:36 PM
The piece I got looks like a hook, is it the wrong part then?
More Information for STANDARD MOTOR PRODUCTS SLS255
  #8 (permalink)
Old 01-06-2013, 07:00 PM
RI-Matt's Avatar
Looks totally wrong and part number doesn't correspond to Navigator or Expeditions.
How much was it at Rock Auto? The OEM switch is only $28 from Tasca.
Should lool like this.
More Information for AIRTEX / WELLS 1S10920
Matt
  #9 (permalink)
Old 01-06-2013, 07:30 PM
Thanks, I even ad my wife and 8 year old looking for my part...
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
