Airbag light 49 - Ford Truck Enthusiasts Forums
Airbag light 49
Old 01-05-2013, 02:06 PM
real_texan real_texan is offline
real_texan is starting off with a positive reputation.
Airbag light 49
I have a 2003 ford explorer with airbag light 49. Does anyone know any common fixes for this light
Old 01-05-2013, 02:43 PM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
A lamp fault code (LFC) of 49 could indicate 1 of 3 different diagnostic codes, all of which relate to the seat track position sensor circuit.
I'd start by carefully inspecting the wiring under the seat for any loose connections or damaged wires.
-Rod
Old 01-05-2013, 05:08 PM
I have looked at the wires. Any other suggestions
Old 01-06-2013, 12:05 PM
shorod's Avatar
If you don't have any obvious wiring issues, the next logical step would be to get the airbag system codes read to determine which of the three possible issues your car is reporting. Possibilities are shorted to power, shorted to ground, or open.
-Rod
airbag light still on emilbolboaca Ranger & B-Series 10 11-28-2006 09:53 PM
Airbag light flashing fordtrucksforever 1978 - 1996 Big Bronco 30 03-14-2006 08:26 PM
airbag light codes chaser1602 1997 - 2003 F150 14 08-31-2005 01:37 PM
flashing airbag light. marragtop 1987 - 1996 F150 & Larger F-Series Trucks 9 10-22-2002 10:40 PM
1997 Airbag light. 1997 - 2003 F150 8 10-01-2002 12:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
