2013 F 150 and weight capacity’s
If you are comparing the exact same trucks (wheelbase, engine, tow packages, HD/non HD, etc) the specifications should be identical or so close it wouldn't matter in real world driving. I just looked up on the Ford website, and there isn't a difference worth mentioning when it comes to payload or towing. Comparing 2 crew cab 4x4 trucks with the same motor and options (save the interiors or decals on the exterior), the towing capacities are going to be the same and payload may vary by 50-100lbs. Where were you getting your information?
I copied and pasted directly from a ford canada website to excel this info
XTR Package 4X4 6.5'
XTR with XLT Luxury Pkg
FX4 4X4 6.5'
Lariat 4X4 6.5'
Towing capacity
2,767kg (6,100lbs)
2,767kg (6,100lbs)
3,538kg (7,800lbs)
3,538kg (7,800lbs)
GCWR
5,307kg (11,700lbs)
5,307kg (11,700lbs)
6,123kg (13,500lbs)
6,123kg (13,500lbs)
Here's a link to Ford's F150 Towing Guide. In this you wont see much, if anything, about capacities based on models. It's cab/bed configuration, engine and 2 vs 4 wheel drive.
http://www.ford.com/resources/ford/g...rv&tt_f150.pdf
Grubbworm
04-21-2011 09:56 PM
