2013 ecoboost and 1st oil change - Ford Truck Enthusiasts Forums
Old 01-05-2013, 08:26 AM
4570 4570 is offline
4570 is starting off with a positive reputation.
I will be recieving a new f 150 with the ecoboost in march sometime.
I plan to do some travel trailer pulling this spring and summer.
So I was thinking of changing all the lubes to amsoil at around 1000 miles, and before using the trailer.
I am new here.
But I have read a few times to stick to ford oil filters, so I will.
I have discussed this with the service manager.
They even offered to do it.
I know I do not need to.
That the factory lubes are good.
Anybody see a problem with this idea?
Old 01-05-2013, 10:38 AM
screwy's Avatar
screwy screwy is offline
screwy has a good reputation on FTE.screwy has a good reputation on FTE.
Whatever oil you use is up to you, so I wont get into that, but I changed mine at 1000 miles. Makes me feel better with the high wear rates at first and not knowing what might have gotten left in there during assembly.
Old 01-05-2013, 07:16 PM
aparise72 aparise72 is offline
aparise72 is starting off with a positive reputation.
Good choice to stick with motorcraft filters. Its up to you on fluids. I use motorcraft fluids, but i have a couple buddies that swear by amsoil.
Old 01-05-2013, 10:25 PM
PrinceValium's Avatar
PrinceValium PrinceValium is offline
PrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to allPrinceValium is a name known to all
Amsoil, Mobile 1, whatever you choose will work well. Synthetics are better than conventional but not everyone agrees with that.
Old 01-05-2013, 11:15 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
I am new here.
When you say ALL the lubes, I'm assuming that you intend to change differential oil, transmission / transfer case fluids as well as engine oil.
Old 01-06-2013, 06:25 AM
Yes, thanks for the clairification.
Quote:
Old 01-06-2013, 10:09 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
There's really no need in my opinion. Modern engines and fluids are capable of going a much longer time than most of us are comfortable without being changed. After 1,000 miles you may have high wear metal content in your oil, but that doesn't mean the oil isn't fully capable of doing its job.
It's not an Ecoboost engine, but I waited to 9,953 miles before I changed the factory fill in my 2011 Mustang. I did a UOA to see how the oil was doing, see below:
As you can see, even after almost ten thousand miles the oil was still perfectly capable of lubricating the engine. Remember that the manufacturer is placing a HUGE wager on the fact that their maintenance recommendations are adequate, as having to replace a blown up engine under warranty would obliterate any profit they made on your truck as well as several others. They own the risk in this situation, and they develop their maintenance intervals with this in mind. You will NOT hurt this thing by following the factory recommended oil changes.
And even more so, replacing your transmission and axle lubricants is even more of a waste, as these fluids will go far longer than engine oil due to a much milder operating environment for them. Many folks never change their differential oil and never have any trouble.
It's your truck and do as you please, but you might as well put your money in a shredder and use it as lawn fertilizer...your truck won't know the difference.
Old 01-06-2013, 11:22 AM
tseekins's Avatar
If one were to run a 25K mile Amsoil product or a 15K mile Mobil1 product through their engine and actually extended the drain cycles out to 25K and 15K respectively and an internal engine failure were to occur, Ford would turn their back on you in a minute for not following the OLM, Oil Life Monitor at a minimum.
Ford will back your engine using the prescribed MC oil and filter for the duration of the OLM or 10K, which ever occurs first. If the OLM were to fail, then you default back to a 5K dump cycle.
Following these drain cycles with such an expensive oil is very interesting. Peace of mind is priceless.
Old 01-06-2013, 05:45 PM
My intention would be to use ford filters.
And to follow ford spec's re drain intervals.
I live in northern canada and have cold winters.
I had to google OLM to see what this is.
I have not recieved the truck yet.
Will my 2013 F 150 ecoboost have OLM?
Old 01-06-2013, 10:48 PM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
Amsoil is second-rate snake oil in my book. Make sure you look at whatever fluids you choose and ensure that are *certified* to the appropriate standard (API, etc.) as required in the owner's manual. Some Amsoil products "meet XYZ standards" but don't bear the official certification mark and aren't really certified. This is Amsoil's way of saying that they think the fluid should be certified, but they haven't spent the money to actually have the certification process performed.
In my opinion, you're trashing a bunch of perfectly good fluids. Dump the oil at 1K... swap over to a full-syn like Mobil 1 if you want, and you'll be just fine. What do you hope to get out of changing all the fluids to Amsoil?
Oil Change in 2013 Ecoboost ARK Ranger 2009 - 2014 F150 18 02-18-2016 02:14 PM
EcoBoost engine care/driving tips? EBXLTF150 2009 - 2014 F150 5 07-02-2014 06:56 AM
Oil Change on New Motor - EcoBoost pdhj1990 2009 - 2014 F150 18 09-23-2012 09:03 PM
Oil change self vs dealer caddy Oil & Lubrication 47 10-11-2009 12:02 AM
JIffy Lube tjsker Expedition & Navigator 11 07-12-2006 05:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
