Is there a cruise control light in instrument cluster??
I have just completed my wiring transplant in my early 99. The donor was a late 99 truck. My truck started out a manual lock, window, and mirror truck and no cruise control. Now, it has all the amenities that were available in a 1999.5 Lariat. I've changed out my clock spring to accommodate cruise control function as well.
My question is, was there ever an indicator light in the dash instrument cluster for cruise control when it was turned on or activated?
If so, does that mean there's a different part number for the instrument cluster on the models with cruise control? Or is there just a light bulb that i need to add behind the cluster to get it to work.
Thanks,
Drake
Thanks,
Drake
I have just completed my wiring transplant in my early 99. It started out a manual lock window and mirror truck and no cruise control. Now, it has all the amenities that were available in 1999 for the Lariat. I've changed out my clock spring to accommodate cruise control function as well.
Thanks,
Drake
Thanks,
Drake
Thanks,
Drake
Ok. I'll let you know when I have the opportunity to check that out and see if there's a bulb in that position. I'll have to pull the cluster to see.
Thanks,
Drake
It wasn't that they didn't have cruise control they just didn't turn on a light on the dash, some people who swapped PCM's to run chips, noticed after they swapped PCM's the light on the dash would then illuminate.
I'll have to wait to check and see if my cruise control works after I get my turbo installed so I can run my truck. My cruise wasn't working before I took it out, but now that I have repaired a lot of my wiring harness, I'm hoping that I also was able to take care of the cruise control.
Right now when I turn my ignition on and all of the lamps in the cluster self test, the cruise control light is not illuminating. When I have time to pull it out and check the wiring leading to the bulb, I'll let you all know what I find. Maybe the cruise lamp does not illuminate during the self test when the ignition is first turned on.
Maybe someone could confirm this?
Thanks,
Drake
Thanks,
Drake
Thanks Tim. Maybe this means there have been issues with my wiring for the cruise control switch or elsewhere in the system. But that bit of info. helps.
Thanks,
Drake
P.S. I feel like I've been banned from giving anyone reps on this forum. I've tried to rep a few people in the last 2 days and each time I'm being told to spread some reps around before giving them to _______ again! Can someone tell me the logic behind who and when I can rep here? I don't feel any of those I've tried to rep recently and been denied are anyone I've repped. for quite a while. What gives here?
