Location of TOT Sensor
Old 01-04-2013, 10:56 PM
erupert66's Avatar
erupert66
erupert66 is offline
I googled quite a bit and found discussions on this board and others related to the TOT sensor but none described the location of the sensor and connection. Other posts indicated that pulling the 636 KOEO code probably indicates a bad connection and not necessarily a bad connection. Can anyone describe roughly where on the transmission this is located? Getting some rather firm shifting and this is the only code related to the tranny.
Old 01-04-2013, 11:03 PM
Puddy's Avatar
Puddy
Puddy is offline
What year truck etc.
Old 01-04-2013, 11:33 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
It's built into the solenoid pack on the transmission.
But yeah, we need more information on the vehicle.
Old 01-05-2013, 07:31 AM
erupert66's Avatar
erupert66
Sorry, it's a 95 F150, 5.8 and E40D
Old 01-05-2013, 08:14 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
The Transmission Oil Temperature (TOT) sensor is located on the Solenoid Pack inside the transmission:
You have to remove the transmission oil pan to get to it.
Why do you think you may have a bad sensor?
Old 01-05-2013, 08:18 AM
erupert66's Avatar
erupert66
Getting a code on it and looking for possible sources for firm downshifts. From perusing other threads, the suggestion is to clean the connection. I assume there is a harness connection on the side of the tranny somewhere
Old 01-05-2013, 08:24 AM
jr32560's Avatar
jr32560
jr32560 is offline
should be a plug on passenger side top of the lip above the pan
try some contact cleaner then dielectric grease chech the pins for corrosion or being bent over-the whole pack comes as a unit-last one I got was around $300 from Ford
had no luck finding it any place else
Old 01-05-2013, 08:29 AM
erupert66's Avatar
erupert66
Thanks. I have contact cleaner and dielectric grease so I'll give that a shot today.
Old 01-05-2013, 11:13 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
E40D Solenoid Pack Block 89 94 E9 F350 F450 F550 Superduty | eBay
Old 01-06-2013, 04:54 PM
rla2005's Avatar
rla2005
If the transmission (and engine) was not warmed before running the KOEO tests this code is very common and not valid.
Old 01-06-2013, 07:33 PM
erupert66's Avatar
erupert66
Thanks, good to know.
Brian460
03-09-2015 08:56 AM
air1jpg
2004 - 2008 F150
02-19-2014 09:22 PM
aphotic26
6.4L Power Stroke Diesel
18
08-30-2013 05:15 PM
undertow91
1997-2006 Expedition & Navigator
02-19-2010 10:31 PM
mtntop1
04-08-2009 10:22 AM
Quick Reply: Location of TOT Sensor
