Offenhauser 2X1 question
Old 01-11-2014, 05:47 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Originally Posted by Damifiknow
I don't recall anything like that on my 1904. I'll go look tomorrow.
Could it be you have a non LoM carb with a LoM dizzy?
I read somewhere that this can cause poor fuel mileage and sluggish performance. I'm not sure how to read the carb #'s to determine which type it is. I also don't have a clue if there were any 223 dizzys made without LoM
  #32
Old 01-11-2014, 06:18 PM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
After further investigation (I went and looked at truck) I do have a LoM and the matching carb on truck now is for a LoM. Two vac lines one from carb and one from manifold. The second glass bowl carb I bought is for a car without a LoM. I now have to change dizzy to make the stuff I have work on the 2x1 offy. Recommendations or link to what dizzy to buy and were to get it? Can my dizzy be modified?
  #33
Old 01-11-2014, 06:32 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Read this all the way through: Help with 215 OHV I6 2x1 set up - The Ford Barn. There are instructions at the end on how to convert a later style 300 dizzy to use with the 215/223 engine.
If you're persistent, you can make it work. I just got tired of it not working right and wanted to drive the truck without dropping more money into it. Let us know how you make out.
  #34
Old 01-11-2014, 07:52 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
This is exactly what I did. I also set it up with a GM (I know, sacrilege) HEI module because it's cheap, see above pic. In my case I got a '64 oil pump as I had the pan off anyway. It has the 5/16 opening for the later oil pump drive shaft used on the Duraspark dizzys. IIRC I bought a new drive shaft and cut it to fit. I had to have the stock dist gear opened up to fit the larger shaft of the Duraspark dist. I had a machinist do it as I know one and we exchange favors on a routine basis.
Seems like a lot of work and it is. But is it worth it? I think so. Ford Duraspark is, IMO, the best dizzy ever made.
  #35
Old 01-11-2014, 08:02 PM
Damifiknow's Avatar
Damifiknow
Thank you Thank you
Knowing all this info why didn't you peruse the fix with a modified dizzy?
  #36
Old 01-11-2014, 08:04 PM
Damifiknow's Avatar
Damifiknow
Thanks for all your help. Prolly tackle this in a month or so after I gather all the parts.
  #37
Old 01-12-2014, 04:51 PM
51PanelMan's Avatar
51PanelMan
Thank you Thank you
Because I was fed up with it. My problem was that I couldn't get the carbs synced well enough. It would work perfect one day, then another would be crappy.
  #38
Old 05-23-2014, 04:20 PM
Damifiknow's Avatar
Damifiknow
When you were fooling around with your duel set up what jets were you using? I got a 64 and a 66 but I think its too much. Any recommendations?
  #39
Old 05-23-2014, 07:36 PM
51PanelMan's Avatar
51PanelMan
I think it had 54s or somewhere around there. I'd think you'd want both jetted low.
BigBody
24
12-30-2011 11:36 AM
Sn0wMan
11-13-2006 10:52 PM
WillyB
09-25-2004 12:59 AM
GeneStoner
04-15-2004 07:20 AM
BLaCkSiLo
28
03-05-2004 12:48 PM
Quick Reply: Offenhauser 2X1 question
