Diehard Platinum or Odysseys? Don't drive much? In here, please
Do any of you use trickle chargers on a vehicle with two Platinum or Odyssey batteries? What do you use, and how well is it working?
I have two vehicles that don't see much use in the winter. The Excursion is driven once a week, my 4Runner is just pulled in and out of the garage a few dozen times between November and April. That lifestyle is tough on batteries.
Both now have newish Diehard Platinum (Odyssey AGM) batteries that are in good shape, and I also have an old Diehard 10/2/60 automatic battery charger. I've read a lot about how to keep these charged, and there seems to be some voodoo involved.
Can I just charge these on the 10a setting 'till they are fully charged, then leave them on the 2a setting for a day or so on the weekends when I'm out in the garage? That seems like it would work fine on regular batteries. Are these Platinums really all that special? Is 2a enough to trickle charge two big Platinum batteries?
Mark
Mark
I am not going to google to figure out if your battery is lead acid or AGM(Absorbed Glass Mat) If lead acid then the different levels of batteries is the surface area of the plates in the batteries which determines the cranking amps. The type of plates/thickness determine if it is a 3 year battery, 4 year or more years. It is no more special than any other battery. It is only advertising. There are only about 3 major battery makers. Every other battery is rebranded. Current is supplied to desulfate the plates or you are using current which sulfates the plates.
I would install the battery tender with the quick connect which will be much less of a hassle for keeping up with.
I'm interested in this also. My truck gets driven once a week at most and is parked outside.
What is the proper method to use this?
Waterproof 800 International - 12V @ 800 mA - USA & Western Hemisphere - Automotive - Products - Batterytender.com
OP, not trying to high-jack your thread.
If you are just maintaining the charge on the battery ....no ....if the batteries are dead you need tl disconnect them fort and charge them with a normal charger. The battery tender is only for maintaining te charge
scottie2hottie
Electrical Systems/Wiring
06-18-2008 07:24 AM
