Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 01-04-2013, 03:31 PM
retrosixty6's Avatar
retrosixty6 retrosixty6 is online now
Garage is empty, add now
retrosixty6 is starting off with a positive reputation.
Alex Klein
Ford 240 in a '60
Hey y'all does anyone know if a 240 will fit up to the factory 3 on the tree bellhousing? If not then will the t98 bellhousing and trans fit in the truck without (much) work? We found out the cylinder heads for the 292 are cracked. We might get replacements later on down the line but for now we are just looking to get the truck driving again.
  #2 (permalink)
Old 01-04-2013, 03:49 PM
f5fordgirl f5fordgirl is offline
f5fordgirl is starting off with a positive reputation.
If you use a 240, nothing from the 292 will bolt up. You'll need the 240 bellhousing, same as small block v8 from 65 up, you'll have to make mounts and add a trans crosmember, different driveshaft but it can be done.
  #3 (permalink)
Old 01-04-2013, 10:22 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
1960 Ford F-100
My Garage
hiball3985 is starting off with a positive reputation.
I don't think you'll be happy with a 240. If you want a later model six go with the 300.
__________________
JIM
1960 F100 Panel 223 3 spd overdrive
1966 F250 390 4 spd
1957 Ranchero 292 3 spd
  #4 (permalink)
Old 01-04-2013, 10:26 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Find a 300 with a trans on it, 3, 4 or 5er. The trans to bell pattern changed somewhere in there to a rectangular or "butterfly" pattern from the old "square" pattern that your T98 has.
  #5 (permalink)
Old 01-05-2013, 10:37 AM
Alex Klein
I already have a 240 with a bellhousing and 4spd out of my '66 rust bucket and that engine runs, so we might just fab up some mounts and use that til we get the y-block rebuilt.
  #6 (permalink)
Old 01-05-2013, 01:40 PM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Nothing wrong with using what you have, that's the true spirit of hot rodding. What are you planning to do for clutch linkage? Modify the original slave cylinder to actuate the clutch?
  #7 (permalink)
Old 01-05-2013, 01:48 PM
hiball3985's Avatar
1960 Ford F-100
My Garage
With all the things that will need to be changed and then change again for the Yblock can't you just wait to instal the Yblock or do you need to have it on the road now?
__________________
JIM
1966 F250 390 4 spd
  #8 (permalink)
Old 01-06-2013, 04:54 PM
Alex Klein
Honestly my pops and younger brother are the owners of the truck so its really up to them, I'm just looking to gather some information for them. And I'm not really sure about the clutch linkage, any tips if we do decide to put in the six?
  #9 (permalink)
Old 01-06-2013, 05:26 PM
hiball3985's Avatar
1960 Ford F-100
My Garage
you are trying to mix apples and oranges as they say. There is no easy way around it that I know of .
__________________
JIM
1966 F250 390 4 spd
  #10 (permalink)
Old 01-06-2013, 08:36 PM
There are some small block Fords in the 80s with external slave hydraulic clutches, a bell housing from one of them might be the easiest.
  #11 (permalink)
Old 01-07-2013, 08:55 AM
Alex Klein
Well thanks for the help guys I guess we'll just keep the six for a later project or something. Like I said I have no real opinion on what to do with this truck I'm just trying to gather information and it looks like it wouldn't be the best idea.
  #12 (permalink)
Old 01-07-2013, 06:32 PM
You might look into a later V8 swap. You can get front and rear cross members for most popular swaps.
  #13 (permalink)
Old 01-07-2013, 09:27 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Some have even re-powered with a diesel.......There's lots of good ones out there.
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
