OIL IN EXHAUST
OIL IN EXHAUST
Drove my truck about 6 miles this morning. Had it plugged in all night and warmed up for about 10 minutes before taking off. Temp was around 2 degrees last night. When I got where I was going a cloud of smoke followed me and overcame the whole truck once I stopped. (Smelled oily). The truck was blowing alot of smoke on the way back too.
I put it up on the rack this afternoon and I have oil dripping from the exhaust pipes where the sections are clamped and also from the top of the down pipe. The truck seems to run fine. I suppose the turbo is bad...taking in oil from the oil feed?? Not sure if that much oil could be coming from the CCV(I have a CCv filter)??
The turbo on the truck is P/N 1854480C91 S/N HKM063855.
Is the new turbo I have a compatible replacement?
From the part number info I have, if you have the 1854480C91 in the truck, then the 1832255C91 should bolt right in (both are for model years after 9/22/03). The pedestal change was made from 9/23/03 on.
http://truckpartsinventory.com/heavy...43561/sterling
http://www.ebay.com/itm/Garrett-1832...-/230871805574
Just to confirm, your ICP sensor is on the passenger manifold, correct?
Engines & Engine Parts | Turbos - Heavy Truck Part Details - (HD) 1832255C91 2006 250.00 28512740048 285-12740048 6.0L 650.00 E350 ECONOLINE Engine Engines Ford GOOD JFM081113 Parts Turbos Used Utah ~|~ Turbo Turbocharger/Supercharger Turbos Ford STE
Garrett 1832255C91 Turbo for 2005 Ford F350 Powerstroke 325 6 0 V8 Diesel | eBay
http://garrettbyhoneywell.com/produc...w.php?id=79905
http://garrettbyhoneywell.com/produc...w.php?id=79901
So what do you all think? Is there a seal on the lubrication side of the turbo that can leak oil into the exhaust? It definitely seems to be coming from the turbo. Also I understand there are some updated components to be used when changing out a turbo. Can someone list the part#'s if possible. Thank you all so much for the advice
I would look into a voltage fuel supply area problem 1st before making a firm decision to do the turbo. U should have 48 volts I believe. If the voltage swings all over the place ( Lower ) repair the problem 1st. Check UR engine oil for diesel fuel dilution. And CCV can be a big problem. Some route to a catchcan.
Mine did that exact same thing. I lost the oil seal on the exhaust side of the turbo. 125$ and about 3 hours and i was back on the road again. It took a good month to get rid of the burning oil smell. I got the rebuild kit from gpopshop.com. Like cheezit said make sure it aint water. Take the exhaust off the turbo and take a look inside there. Youll know whether its water or oil right away.
