Thinking about a 2013 - Ford Truck Enthusiasts Forums
Old 01-04-2013, 09:40 AM
bsfarmer bsfarmer is offline
bsfarmer is starting off with a positive reputation.
Been shopping around for a new F250 or F350. Going from a '12 Chevy 3500HD 6.0 gasser regular cab work truck to a 4-door diesel Lariat fully loaded. I plow snow and pull a 16K lb equipment trailer around, and put around 20K miles on a truck each year. Plan on trading trucks every 5-7 years.
Questions is---how many guys on here have had ZERO problems with their new 6.7's? I know people don't usually post about how trouble free their truck has been and you always hear horror stories from all three trucks, whether its problems with DEF, EGR, or hubs not locking in or balljoints wearing out or something.
IMO you pay 50-60K for a pickup truck you should not have to take it back to the dealer for anything....at all. You should only have to do oil changes, tire rotations, and scheduled maintenance for at least 100,000 miles. That's the reason I bought a GM 6.0 gasser, proven to be a reliable truck and motor, but just a little lackluster in the power and MPG department. Its done everything I've asked it too, but 8mpg gets a little old and a little more pulling power would be nice.
I guess what I need is just a little convincing to switch back over to a Ford instead of getting another GM product or changing over to a '13 Ram Laramie.
Old 01-04-2013, 10:06 AM
CascadeF250's Avatar
CascadeF250 CascadeF250 is online now
CascadeF250 is gaining momentum as a positive member of FTE.
40,000 miles and one faulty water pump at 22,000 , also computer update for DEF fault. Truck pulls something about half of the time. I guess I can't say 0 issues but Dealers response to problems was excellent. I would purchase the same truck again.
Old 01-04-2013, 10:11 AM
jim48's Avatar
jim48 jim48 is offline
jim48 has a good reputation on FTE.jim48 has a good reputation on FTE.jim48 has a good reputation on FTE.
NO problems with my truck. As you can see my truck is a chassis cab, hence a puny 300 hp instead of 400 hp. My dealer sells a lot of chassis cabs as we live in the middle of wheat/cattle country. I've know this dealer all my 65 years, and they have been family owned for more years than that. They've had very few 6.7 owner's issues of any kind. They have a VERY sharp diesel mechanic, and he says so far the engine has been a winner. He has seen two for fuel/water issues, and it looks like both were drivers mistakes.
We only use our truck to pull 5th wheel, and it does the job effortlessly. We had a 04 FX4 F250 6.0 before. This truck pulls the same 5th wheel so much easier, and gets better fuel mileage to boot. Quiet, comfortable and a joy to drive, what's not to like???? We get 19-21 mpg empty and 10.5-13.5 mpg pulling the fiver. I have a 4.11 rearend and drive 60 mph regardless of empty or loaded. 90% of our towing mileage is 12.5 mpg and it only changes with the prevailing wind or lack of.
Good luck with your choice...........
Jim
Old 01-04-2013, 10:19 AM
los341's Avatar
los341 los341 is offline
los341 is starting off with a positive reputation.
9K miles and zero problems here so far... Our first big trip was pulling a fifth-wheel out to Maine and back. Had a blast!
Regarding the comment of there should be no problems before 100k miles... personally I think that's an un-realistic expectation for a truck as big and complicated as these. Heck, that's a lot to expect even from a plain-jane car base-model car that only grandma drives! I think you can expect a few problems. That comes with the territory and is also why it comes with a warranty. These trucks are designed to work hard while keeping the occupants safe and comfortable, but they're not perfect. Treat it well and it will treat you well!
Carl
Old 01-04-2013, 10:24 AM
Troy Buenger's Avatar
Troy Buenger Troy Buenger is offline
Troy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to beholdTroy Buenger is a splendid one to behold
~14k miles on my '12 and not a single problem.
Excellent fuel economy and tows/runs like a beast...
My best truck to date.
BTW... If you keep trucks every 5-7 years I'm surprised you are ready to dump your '12 GM 6.0. To take a major hit on trade in/or sell can buy alot of gasoline for that gasoline guzzling truck.
Old 01-04-2013, 12:05 PM
2ndStroke's Avatar
2ndStroke 2ndStroke is offline
2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation2ndStroke has a superb reputation
Owned my 6.7 for a year and a half now. Had 2 check engine lights for bad sensors in the first 6 months, the last year has been flawless, no issues. The last flash has helped a lot with the shifting, which was the only thing that annoyed me with this truck.
Old 01-04-2013, 03:43 PM
Jefff H Jefff H is offline
Jefff H is starting off with a positive reputation.
My 2012 F350 has 20k and no problems.
My last 5 new gas trucks have all went over 100K without problems. Four Fords and one GM.
Being new to diesel I'm getting the impression that Power Stroke owners seem to expect problems and consider them normal. I mean no offense, but I have never seen problems like I've been seeing here with the gas motors.
Old 01-04-2013, 03:54 PM
los341's Avatar
Uh yeah, machines break, hence the problem occurs. Fords, Chevys, and Dodges all do it.
Maybe the "problem" here is how we define a problem. Any time something breaks or no longer works correctly, that to me is a failure, and hence a problem. If a power window stops going up, I would consider that a problem. If there is a small oil leak, that's a problem too. CEL is a problem. Funny squeak or rattle is... you guessed it, a problem.
So by my definition, if you have had 5 gas trucks, and every one of them went over 100k miles without a single problem, then that to me is beyond phenomenal. That is galactically amazing, and statistically virtually impossible! So either one of two things are going on here... either 1: You are the luckiest living organism ever to live, or 2: You definition of "problem" is a little more relaxed than mine.
Carl
Old 01-04-2013, 04:48 PM
Carl
No need to attack.
Like I said please don't take offense, but you are proving my point. The Power Stroke engine line has more problems than any engine in the history of engines. Having said that I have taken a chance on my '12 and hope to break the cycle, but I will not bury my head in the sand! Oh and I did have a radiator hose pop off one of those trucks. Please forgive me.
Old 01-04-2013, 05:10 PM
Joe_planet Joe_planet is offline
Joe_planet is starting off with a positive reputation.
No need to attack.
If you made an internet forum for every make and model and asked people what problems they've had I'm sure you'd fill every forum.
The truck comes with a warranty. Nothing is perfect.
Old 01-04-2013, 05:11 PM
los341's Avatar
No need to attack.
I fail to see how what I said could be interpreted as an attack.
I never felt offended, nor did I indicate such.
I don't see how anything I said goes toward proving your point sir.
Well that seems like a broad statement to me. We are talking about the 6.7L engine, not the entire Powerstroke engine line, are we not? Regardless, I've owned Fords, Chevys, and Dodges all my life and have no affinity towards any particular brand. However, as I'm sure you can tell, I am VERY fond of my current truck! It has served its purpose well.
I wish you the best of luck on the risky chance you took by purchasing a Powerstroke sir. I hope the odds pay off for you. However, I am curious as to why you bought it if you consider the Powerstroke to be the most problematic engine in the history of engines!
Carl
Old 01-04-2013, 05:30 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Quote:
Here's the problem with this statement... This is Ford Truck ENTHUSIASTS. Most of us are enthusiastic about our trucks. If you really want to poll truck owners, it's probably in your best interest to be on a GM, Chrysler and Toyota Forum and ask them how may problems they've had as well. You will find lots of people that have problems. My inlaws have a Tundra that has given them problems. My buddy is in Finance at one of the largest Dodge dealers in Texas and Ram's come in all the time with problems. I'm sure GM has the same. Realistically, you need to buy what YOU want and suits your needs. We live in an imperfect world.
The reality is, many of the members on sites such as this most likely became members because they were searching for solutions to a PROBLEM. I see it almost daily. A newbie shows up with 1-5 posts and asks what a CEL means or why they're getting a knocking sound or why their AC isn't working.
Just my $.02.
Old 01-04-2013, 05:37 PM
Chad149's Avatar
Chad149 Chad149 is online now
Deplorable
Chad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputationChad149 has a superb reputation
17k on my 2012 6.7. No problems what so ever. P.S.-in my friendship circle Dodge Cummins has had the most trucks bought back under lemon law! But we beat the heck out of them:-)
Old 01-04-2013, 07:58 PM
Dagmandt's Avatar
Dagmandt Dagmandt is offline
Dagmandt is starting off with a positive reputation.
I had seat belt clasps on my '12 that creaked and popped like crazy. Dealer replaced both without so much as a whimper and the replacements are great. 2,000 miles and no other problems as one would expect with such low mileage. Only had it a short while.
Old 01-04-2013, 08:16 PM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
No issues with the 6.7L engine.
I did have solenoids replaced in the transmission and the front diff began leaking so it was resealed.
Truck runs better at 40,000 than it did at 4 when I got it.
From a 6.2 to a 6.7....... Just my first thoughts. Amelio 1999 to 2016 Super Duty 15 12-14-2014 09:14 PM
My Take on this Truck! jfralph 6.7L Power Stroke Diesel 9 06-06-2013 10:12 PM
Experiences with used E350 and 6.0L PSD? zuren 1968-2013 Full Size Vans 7 09-03-2010 11:28 PM
Looking at buying a 2004 SD with 6.0L Diesel... questions inside Tungsten 1999 to 2016 Super Duty 32 10-18-2007 05:22 AM
Said Good Bye to my F250 EddieHaskell General NON-Automotive Conversation 17 07-22-2003 12:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
