Electric wiper
Old 01-06-2013, 08:34 AM
1930 Dodge's Avatar
1930 Dodge
1930 Dodge is offline
Originally Posted by DR Smith
If your 6 volt wipers work and you have converted to 12 volt,why don't you install a 6 volt 12 volt from antiqueautobattery.com 800 426 7580. I used one in a 38 Packard that used 12 volts for starting and 6 volts for every thing else. It has three terminals,ground,6 volt,and 12 volt.Run 12 volt off the key switch and have a relay that opens when the key switch is on,to power up 6 volt stuff.
Someone else mentioned this and showed me a site of where these are sold, I need to call on Mon for some clarification, their pictures look like it is a different kind of battery, specialty battery, your desc. makes it sound like something I place onto my existing battery, which is it please? Cost ( approx ) would be nice as well
  #47
Old 01-06-2013, 09:05 AM
DR Smith's Avatar
DR Smith
DR Smith is offline
It looks just like a regular battery.lower right corner,in picture.It states that switch comes with battery,to change from 6-12 volts about $225.This price is about 4 years old. middle second up is just the 6-12 battery for $145.
  #48
Old 01-06-2013, 02:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
It might be worth signing up on the HAMB and asking over there. Our trucks are among the last using vacuum wipers so many of the guys over there have fab'd up wipers from more modern stuff. Hokey *** Message Board - THE H.A.M.B.
  #49
Old 01-06-2013, 02:48 PM
Oz52F1's Avatar
Oz52F1
Oz52F1 is offline
  #50
Old 01-06-2013, 03:16 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
Those antique auto batteries, 6v and 12v.... can you say how long they last with regular use?
  #51
Old 01-06-2013, 04:04 PM
1930 Dodge's Avatar
1930 Dodge
Wow, thats kinda what I thought, it is an entire battery, doesnt seem like its going to be the best alternative for my situation but thank-you for taking the time to post the info anyway, I am also curious about longevity.
  #52
Old 01-06-2013, 04:05 PM
1930 Dodge's Avatar
1930 Dodge
Thanks, I do have the question posted on another hot rod board and will wait to see what sort of a response I get there.
  #53
Old 01-06-2013, 04:06 PM
1930 Dodge's Avatar
1930 Dodge
Originally Posted by Oz52F1
Very good, thanks, will check it out
  #54
Old 01-06-2013, 05:09 PM
DR Smith's Avatar
DR Smith
DR Smith is offline
The one that I worked on was in the car about 3 years and still going strong.With that said,the car didn't get used much.WE did have a battery tender hooked up when the car sat.
  #55
Old 01-06-2013, 07:19 PM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
Till there are dead
  #56
Old 01-06-2013, 07:41 PM
1930 Dodge's Avatar
1930 Dodge
Thanks for the info, I have some older cars and have been recommended a battery tender and will have to go ahead and make the purchase. I have not heard a downfall to these.
  #57
Old 01-07-2013, 04:51 AM
1930 Dodge's Avatar
1930 Dodge
I have been asking around on different forums about identifying this set-up further or closer, from the responses I am getting here and over there I guess its safe to assume that this set-up is a mix of parts and not from any one specific vehicle is that correct?
  #58
Old 01-07-2013, 12:01 PM
jonf's Avatar
jonf
jonf is offline
Add a 6-volt lug to the battery?
In days of old when 12-volt batteries first came out, we could still get six volts by putting a screw into the middle of the top of the battery. The screw went into the link connecting the individual cells of the battery.
Would this still work??
  #59
Old 01-07-2013, 12:28 PM
1930 Dodge's Avatar
1930 Dodge
I have read about this as well, on a sidenote I guess I forgot to add here that I went ahead and purchased this Ron Francis Wiring Voltage Reducers VR4 - SummitRacing.com From what I have heard it will do what I want it to do and then some, tired of screwing around with this wiper so I disregarded the cost
  #60
Old 01-07-2013, 12:36 PM
Steve_B's Avatar
Steve_B
Steve_B is offline
This set up was made by Lucas (q jokes about Lucas electrics being made of smoke) and fitted to many UK cars in the 60s and 70s. It was used in minis, jags, vauxhalls and probably a few others
It's easy to fit and modify to suit as its cable drive so the motor can be mounted out of the way, gives 2 speeds with auto park, The tubes are easily cut to adjust spacing between the wipers
All parts are available new
Wiper Systems & Parts - Classic &AMP Vintage Car Parts from SVC - The Best Prices
I've used one in my truck, there are a few pic's in my gallery
Quick Reply: Electric wiper
