Tool kit recommendation
Hey, I bought a 1994 F250 to use as a work/play truck. What tool kit would you recommend? And what spare parts would you recommend I keep in the truck?
I'm often off the beaten path.
It seems most tools are not American made, I prefer an American made set.
Thanks, Jeff
Thanks, Jeff
I always use Craftsman tools. They're guaranteed for life. If one breaks, take it back and you get a brand new one. Hard to beat a guarantee like that. But no matter what tools you have on your truck, you always need something you don't have.
I have some big 100 and some piece ratchet set I keep in my truck, plus some relays, fuses, an a wiring kit. I also have a screw driver set and a few sets of pliers and some zip ties. Of course, that isn't enough tools to fix everything, but I can fix a lot of stuff on the go. A toolbox in the bed is also very handy so you have room to keep your things.
My truck is kind of a rolling toolbox so I have most everything I need in it, but for my car I have the Craftsman 154 piece kit, costs around $89 and has most of the basic hand tools you would need in a pinch.
Its a little short on wrenches, the largest is 5/8's I think, probably about as big as you are likely to use on the side of the road, but you could always pick up a few more, say up to 18mm. I think a set of wrenches up to that are like $20, same for comparable SAE.
There is a little extra space in the case and I put a knife or two in there, some black electric tape, a bit of wire, and a pair of needle nose and a pair of regular pliers and some other odds and ends, small chisel, punch, etc....
As a side note, make sure the case is the right way up before you open it. I don't use that set very often and have on ocassion opened it wrong way up, not pretty.
I also have a 2 1/2 pd short handled driving hammer, a couple pair of good vice grips, a cheater bar, and some decent jumper cables, and a can of PB Blaster.
And in a small bag that used to be a lunch cooler I have a multimeter and a test light, some connectors, zip ties, some electrical wire, etc.
Finally (I think) I have one of those large plastic jars that cheese ***** or pretzels come in - a little over gallon size I would say - full of various fuses, relays, bulbs and various items like that I have collected from junking cars/trucks and or trips to the upullit.
I keep all this inside a spare kitchen sink wedged in on the passenger side of the trunk, lol. Actually I have an olds 88 and it doesn't take up that much trunk space. Also have a quart of oil, and a quart of trans fluid, and a small bottle of brake fluid in there too, probably a antifreeze jug with water as well.
I seldom use this stuff for myself anymore, but I have helped several people on the side of the road, and when I used to sell parts on CL from a lot with 100 or so vehicles it was much handier than having to get my truck everytime.
I'm not usually into universal tool sets, but my wife got the following kit for me that I take to salvage yards and the like:
Craftsman 58PC UNIVERSAL MAX AXESS MECHANICS TOOL SET - Tools - Tool Sets - Mechanics Tool Sets
I will say this set was put together well. The only things I take in addition to this set is a set of screwdrivers, a pry bar, a break over, and your standard pliers such a vice grips and large adjustable end wrench. I would say that you should be able to take care of just about anything you would want to tackle on the side of the road with this set up. Of course, having things like jumper cables with a case, a cheater bar, a good jack, and the other things bdelmar2 mentioned above are also a must. I also like to carry a 20ft logging chain or ******/winch strap for helping others or doing truck stuff like moving trees. A good locking toolbox in your bed can be a good thing to have with all of these things, especially if you like to keep things like speakers behind your seat. However, all of the things you need should be able to be kept behind your seat if organized nicely. That is one of the reasons I like the set above so much.
I was told a long time ago that if I need to borrow a tool more than twice from a coworker or friend, I needed to purchase it for myself. That was probably the best advice I was given regarding tools as it's easy to get wrapped up in "I might need that someday" and buy things you don't really need. Most big sets of tools have a lot of things and sizes you really don't need.
