5 Speed manual shift problem - Ford Truck Enthusiasts Forums
Old 01-03-2013, 11:35 PM
MCovey1 MCovey1 is offline
MCovey1 is starting off with a positive reputation.
I have a 1995 F150 with a 302 and a 5-speed manual. I recently replaced the slave and master cylinders. The clutch itself is nearly new and in great shape, and everything else appears to be as well. However, I still have a problem shifting from first to second. If I take off in second, everything shifts smoothly. If I start in first and try to shift to second, I can't get the shifter into second. I just have to skip to third. Can't figure out why. Any advice would be appreciated!
Old 01-04-2013, 12:00 AM
DManikowski DManikowski is offline
DManikowski is starting off with a positive reputation.
Most likely an internal transmission problem in my opinion..
If its a M5OD then i'd say this is a good time to get a ZF
Old 01-04-2013, 12:06 AM
Iversen-fords's Avatar
Iversen-fords Iversen-fords is offline
Iversen-fords is starting off with a positive reputation.
sounds like a synchronizer but thats my guess. it could be related to a shift tower problem also. good luck finding ZF5 for small blocks. They are a little harder to come by at where i live.
Old 01-04-2013, 12:18 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Possibly the shift fork. You should have an inspection cover in the floor of the cab. From there, you can pull the top of the trans and see the forks, and replace them if need be.
M5OD Mazda Design Manual Five Speed Transmission Preventative Measure .: Articles
Post 8 for parts, and post 9 for a gold mine of pics and explanations on how to take the top off and what you'll find. I think it's a Tbird trans, but they are all Mazda boxes and all pretty much the same design.
http://www.ford-trucks.com/forums/10...d-refresh.html
Old 01-04-2013, 12:23 AM
Thanks for the tips, guys! Yeah, it's an M5OD and I have no doubt that a ZF would be nice, but if they are rare I will just see what fixing a synchronizer involves.
Old 01-04-2013, 12:24 AM
Just saw your post, 85. Thanks for the info! I will check that out.
Old 01-04-2013, 12:29 AM
I've actually stumbled upon quite a few small block ZF's in my area(lower pa, upper md)
Old 01-04-2013, 04:38 AM
fdude64's Avatar
fdude64 fdude64 is offline
fdude64 is gaining momentum as a positive member of FTE.
I have a small block zf 2wd sitting on my engine stand and cant give it away. going to disassemble and scrap soon
Old 01-04-2013, 11:21 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
my 88 has shifting problems, turns out that the clutch hanger was wore out, too much play causing it to not get a full stroke on the master cylinder. however it was both from first to second and when downshifting from second to first. was like a new transmission after fixing.
Old 01-04-2013, 11:52 PM
My F150 is a 4x4, but maybe I could find something that would work. Actually muscletruck, that might be something. It doesn't like to shift back to first until I come to a stop.
Old 01-05-2013, 09:43 AM
Hutch17's Avatar
Hutch17 Hutch17 is offline
Hutch17 is starting off with a positive reputation.
[quote=Iversen-fords;12673288]sounds like a synchronizer but thats my guess. quote]
X2 My cousin had this same problem in his jeep, yes I know different manufacturer but same problem
99 super duty 5.4 shifting problem Dustinlen87 1999 to 2016 Super Duty 1 10-06-2016 07:45 PM
1994 F350 7.5 E4OD 2nd to 3rd gear problems. UrMedic 1987 - 1996 F150 & Larger F-Series Trucks 2 01-21-2016 08:12 AM
Transmission sticks in frist, second or third zrone90 1999 to 2016 Super Duty 15 08-25-2015 09:01 AM
not sure if i can salvage my t98 moorfiend 1961 - 1966 F-100 & Larger F-Series Trucks 6 02-06-2015 09:38 PM
86 F150 ticking noise mchbts 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-05-2009 12:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
