2" of play in steering wheel - Ford Truck Enthusiasts Forums
Old 01-03-2013, 10:18 PM
mike L mike L is offline
mike L is starting off with a positive reputation.
Is 2" of play in my steering wheel normal? Is there any other adjustment I can make? The front checked out ok, state inspection. Before adjusting the gearbox (nut) a little. It was two hands on the wheel at all times. The gearbox never leaked and it's not to bad to drive with one hand, now.
Thanks,
93 f510 150,000
Old 01-03-2013, 10:49 PM
Nickk97tml's Avatar
Nickk97tml Nickk97tml is offline
Nickk97tml has a good reputation on FTE.Nickk97tml has a good reputation on FTE.
My truck always had this problem, even before the lift. I have replaced all ball joints, tie rod ends, draglinks, had a professional alignment, tightened all connections to and from the gear box/pitman arm. All that for nothing. When other people drive it they say its all over the road and unbearable but im use to it.
Old 01-03-2013, 11:20 PM
Quote:
Originally Posted by Nickk97tml View Post
My truck always had this problem, even before the lift. I have replaced all ball joints, tie rod ends, drag links, had a professional alignment, tightened all connections to and from the gear box/ pitman arm. All that for nothing. When other people drive it they say its all over the road and unbearable but im use to it.
Do you have a adjusting nut/screwl on top of your steering box? I turned mine to the right a little at a time and it helped.
Old 01-04-2013, 12:58 AM
Nickk97tml's Avatar
Quote:
yeah, I believe so, I may have to try this. how much do you feel it helped?
Old 01-04-2013, 01:06 AM
88n94 88n94 is offline
88n94 is gaining momentum as a positive member of FTE.
To mike L. I wouldn't put much faith in that STATE INSPECTION you mentioned. I'm betting you have a worn basic steering component. Either the drag link or a tie rod end or closely associated part.
Turn your ignition switch to unlock the steering wheel, DO NOT START THE ENGINE. Get an assistant to slowly turn the steering wheel back and forth about three inches. Crawl under the truck and closely watch the stuff I mentioned above for play.
Old 01-04-2013, 06:36 AM
It was worth doing! I had to drive with both hands before, now just one hand. I loosened the nut and turned the screw to the right to tightening the steering. I went 1/8" at a time. I heard don't go to much!! ?????? Post a new question first with adjusting steering gear box. The guys answer right away. I found out every little problem i have with the truck there's always good answer here.
Old 01-04-2013, 06:51 AM
DIYiT's Avatar
DIYiT DIYiT is offline
DIYiT has a good reputation on FTE.DIYiT has a good reputation on FTE.
Make sure you check the u joints in the shaft from the steering wheel to the gear box. Mine has some play in the shaft, and a lot of play in the drag link and tie rod ends.
Old 01-04-2013, 07:11 AM
bdelmar2 bdelmar2 is offline
bdelmar2 is starting off with a positive reputation.
Yeah, you want to take your time tighting the steering box nut. If you go too far it will wear the box completely out faster.
It also makes the truck steer hard, you get bump steer and will drive really strangely, dangerous even.
Also, it seems more difficult to get the adjuster to back off than tighten down, so sneaking up on it is easier.
Technically you really aren't supposed to change the lash or preload on a steering box after its inital adjustment except when rebuilding the box, but I've known people to tighten it up and drive for years.
Old 01-04-2013, 11:17 AM
I would mess with the steering box nut only as a very last resort. I've never had to do it, but I had a neighbor who always messed with the steering box nut, so I know what can happen.
Old 01-04-2013, 11:51 PM
SCRebel's Avatar
SCRebel SCRebel is offline
SCRebel is starting off with a positive reputation.
I know with mine, my play is just in the steering shaft going to the gear box, not the gear box its self. I just havent gotten around to hunting down the parts needed and replacing them. Also considering its my DD and I drive it everyday makes it harder to fix.
Old 01-07-2013, 09:00 AM
DIYiT's Avatar
Just as a general question, are the gear boxes rebuildable, or is it cheaper/easier to just replace the whole thing?
Steering Gearbox questions rustydailey 1999 - 2003 7.3L Power Stroke Diesel 1 07-29-2012 01:36 AM
Steering play sparrish65492 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 12-21-2011 01:14 AM
steering play problems neader General Diesel Discussion 0 12-11-2011 04:22 PM
Manual steering box adjustment rikg 1967 - 1972 F-100 & Larger F-Series Trucks 1 08-26-2004 09:33 PM
F-150 Steering Gear Box Adjustment roryrhodes 1987 - 1996 F150 & Larger F-Series Trucks 5 10-20-2003 11:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
