Transit Connect 2010+ Ford Transit Connect
Drivers window goes down, but not up??
Old 01-03-2013, 10:11 PM
archangel's Avatar
archangel
archangel is offline
It started out occasionaly, but now we never roll it down as it can take up to 10 minutes of fiddling with the switch to get it to go back up.
Things that come to mind first are the switch, a loose wire, or a dead spot in the motor that is in the right spot when it stops in the down position.
Another forum mentioned something about there being a relay in the door causing the window to go down on it's own after turning the engine off, then starting it again (not my issue but possibly the same part misbehaving).
I thought I'd ask before tearing things apart just in case someone had the issue as well.
I'm also waiting for warmer weather.
Old 08-03-2013, 09:10 AM
archangel's Avatar
archangel
When I removed the switches and swapped them around, the problem went with the switch, so that is the problem.
Huntington
1999 to 2016 Super Duty
21
09-30-2020 02:09 PM
Krazyhorse93
10-14-2016 02:00 PM
timbersteel
09-23-2013 07:14 AM
randomhero1172
08-02-2008 09:21 PM
daddy_k
11-17-2007 09:02 AM
Quick Reply: Drivers window goes down, but not up??
