Transmission leak - Ford Truck Enthusiasts Forums
Transmission leak
Old 01-03-2013, 04:07 PM
chaser1602 chaser1602 is offline
chaser1602 is starting off with a positive reputation.
Transmission leak
2000 f150 2wd. Drained and replaced trans fluid and filter few years ago and used the cork gasket in the filter kit. It leaked. Replaced it with another cork gasket and used silicone that time. Still leaked. Replaced 2nd gasket with the reusable oem gasket. Its leaking. Bolts have been torqued to whatever the manual says. What can I do about this
Old 01-03-2013, 04:36 PM
vaper vaper is offline
vaper is starting off with a positive reputation.
If you are sure it is the pan leaking my guess is the pan is bent.
Take a straight edge and check the mating surface,straighten any low/high spots.
good luck
Old 01-03-2013, 06:16 PM
Lime1GT Lime1GT is offline
Lime1GT is starting off with a positive reputation.
Sometimes the seals from the shifter shaft and other attached pieces can leak and run along the pan giving false impressions.
Old 01-03-2013, 06:29 PM
I cant imagine it being bent. Not like I have abuse it. And shifter shaft is not leaking. It's dry around it
Old 01-03-2013, 06:35 PM
Quote:
Doesn't take much,even prying it off a bit with a screw driver will do it.
Old 01-03-2013, 07:06 PM
vfast vfast is offline
vfast is starting off with a positive reputation.
take sandpaper and ruff up the area for the gasket on a flat surface...get a gasket from ford it doesn't need prematex it had ridges in it and it reuseable
Old 01-03-2013, 07:07 PM
the cork gaskets will soak up fluid and leak
Old 01-03-2013, 09:12 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
If some of the pan bolts have been overtightened, the bolt head may have dimpled the area around the bolt hole. If so, with the pan off, try putting a block of wood under each bolt hole in the pan and tapping the dimple down with a small hammer. (The bolts will pull a dimple tight up againt the mating surface, but the gasket between dimples will not have sufficent pressure to prevent leaks.)
Old 01-04-2013, 01:27 PM
coolray coolray is offline
coolray is starting off with a positive reputation.
I've had the o-ring on the fill/dip stick go back on one.
Old 01-04-2013, 01:42 PM
monkeyspain monkeyspain is offline
monkeyspain is starting off with a positive reputation.
I know that you have prob already done this but double checking the obvious. Make sure that you have scraped all of the old gasket and permatex off the pan as well as the case. an old fashioned scaping can prevent alot of probs
Old 01-04-2013, 05:10 PM
I haven't been able to go look, but I had to tighten up the fitting for the cooler line not long ago. Gotta do that, probly time to replace it
Old 03-06-2013, 08:19 PM
Update
With the weather permitting got a little more accomplished. It is dry around the cooler lines. Took a hammer and punch and went along the edge of the pan, cleaned it up foe a test drive. Looked like it was leaking around the speed sense so the orings got replaced. Just did that 2 days ago. So cleaned it up again and have to wait for another good day of weather. If it isn't the orings the next thing is going to be the tailshaft housing gasket
thoughts on using RTV with a gasket granny_rocket 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 10-23-2013 10:47 PM
Should i use rtv??? ar156920 1973 - 1979 F-100 & Larger F-Series Trucks 6 08-04-2009 01:11 PM
4R100 Tranny Gasket wont seal Anyone have this problem? 60RatRod 1999 - 2003 7.3L Power Stroke Diesel 12 12-05-2008 07:41 PM
E40D Pan gasket...which one? mattsautobody442 Clutch, Transmission, Differential, Axle & Transfer Case 7 10-24-2008 11:50 PM
Valve Covers jdwitte Ranger & B-Series 4 08-16-2004 08:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
