1994 F250 7.3 IDI - Hard Start/Fuel Leak - Ford Truck Enthusiasts Forums
Old 01-03-2013, 01:23 PM
fieroboom fieroboom is offline
fieroboom is starting off with a positive reputation.
Hey guys, new to the forum here...
As the title says, I have a 1994 F250 7.3L non-turbo IDI. It was a farm truck, I bought it @ 171k miles (first diesel to own, although I've worked on a few before), and now that I'm using it as a DD, things are starting to break/unravel... I noticed it getting progressively harder to start after sitting for an hour or so, so I did a bunch of reading & research, and determined that my particular set of symptoms (WTS & GP Relay properly functioning) must be due to a leaking fuel line, allowing the system to de-prime once it's turned off. I closely inspected the injector pump, and sure enough, the center supply line (from the filter assembly) is loose enough at the pump that I can move it in & out with my hand, and it & the valley are covered in fuel as well.
Now, my question is, what "kit" do I need to buy? I realize that ideally, I would replace all the seals in this portion of the system, since the others can't be too far off from failing, so does that mean I need to get the injector seal kit and an "Injector Pump Installation Kit"?
I'm just needing a little guidance on the exact seal(s) or set(s) of seal(s) needed to repair the current issue, as well as maybe do a little preventative maintenance. With all the diesels I've worked on in the past, the owners had already purchased the parts, & I just installed them.
Thanks so much for your time & advice; this forum has already been a wealth of information!
Old 01-03-2013, 02:56 PM
Wow, thanks for the detailed, quick response! I'm gonna get those ordered ASAP.
UPDATED Fuel Injector Top O-Rings/Seals ~ The Whole Story creator 6.0L Power Stroke Diesel 123 03-28-2016 08:39 PM
1994 7.3L IDI TURBO FUEL RETURN LINE ? kjjr20 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-18-2014 05:16 PM
1994 7.3 IDI Non Turbo Won't start jblueep Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 53 02-16-2014 08:05 PM
Glow Plugs -- Now With Pictures! krogoski Indiana Chapter 8 02-14-2011 03:28 PM
92 7.3 IDI engine problems Ericsfords Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 42 11-11-2010 01:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
