1999 F350 diesel with Surging issues - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-03-2013, 12:28 PM
Rodneys Rodneys is offline
Rodneys is starting off with a positive reputation.
I have a stock F350 6spd diesel that is surging badly. I thought it was fuel issue and still do. No codes. The issue is intermediately at driving speed or idle cutting out and surging. Acting like it is running out of fuel. I have changed the fuel filter and ran an additive to the fuel.
Any help or ideas of what could cause it. Is there just the one fuel filter on the truck?
Old 01-03-2013, 06:51 PM
MauleOne MauleOne is offline
MauleOne is starting off with a positive reputation.
Surging
Sorry I can't be any help but I have the same problem and am watching to see answers you get.
Good luck
Old 01-03-2013, 07:43 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
There is just one fuel filter on the truck(That is easily serviced and intended for service) There are screens inside the fuel tank mixing chamber that can become clogged as well as a screen on the inlet of the fuel pump.
So you are not getting an "SES" light.
I would lean first towards a CPS, as they are about the only thing I would just "throw" at the truck without further diagnosis.
Then I would want to view live data, and observe ICP and IPR as a faulty IPR or wiring issue can cause some of these symptoms.
If you feel as though you are actually running out of fuel, at a minimum a temporary fuel pressure gauge plumbed into the fuel bowl drain will help to see that.
Consider posting in the 1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums to get a more specific view of your issues as well.
Old 01-03-2013, 08:50 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
When is the last time you changed the oil? Is the oil full? What type of oil is it?
Fuel pump issue? Jcd99d 1999 to 2016 Super Duty 0 05-22-2014 09:12 AM
5.4 surge in RPM at startup stredway 1999 to 2016 Super Duty 10 10-21-2011 09:46 AM
Start up idle surge in 1997 F350 7.3L power stroke diesel wmsgrill 1994.5 - 1997 7.3L Power Stroke Diesel 2 09-18-2011 11:16 PM
Surging on startup... JAFO1 1994.5 - 1997 7.3L Power Stroke Diesel 20 05-19-2010 03:25 PM
97 f350 diesel choking, stalling trouble txcowboy67 1994.5 - 1997 7.3L Power Stroke Diesel 3 09-19-2005 04:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
