100hp Injectors
the tranny is stock, never touched it. but my injectors wents out and im looking to gain a little more power while i have it all apart and i figured just putting stage one injectors in it would give me some more power but wasnt sure if i would need to buy anything extra to power the injectors or not... like i said i have a cold air intake exhaust and a chip on it. just looking for a little more power.
Take a look at Swamps diesel. They are the ONLY company that's builds their own injectors and also does their own tuning. I like the idea of no finger pointing between the injector suplyer and the tuning company. Swamps may not be the cheapest but, They have the best warranty you will find.
Also he works very closely with Matt at Gearhead performance for the tuning. Matt has had several trucks in Diesel power lately that he has tuned. (the most of anyone I beleive).
However swamps is great along with all the others. If one was close to you that is who I would go with. I wish I was closer to Matt so I could get live tuned.
I think you need to be the first to go with the 20% over stock injectors you mentioned and then tell us how you like them. They should work with your tuner the way it is till you can get live tuned. Should put you in the same place as the stage one 160 AC's or close. If you go bigger you better have gauges. Let us know what you do please.
i do have gauges, EGT, Tranny Temp, and Boost gauges. i talked to the guys at riff raff and they said i would have to get a bigger fuel pump for my truck to run right on stage one injectors, so i just ordered stock injectors.
is there anything i can do to my truck to make it run better without paying a fortune?
I'm running 160s on stock ...original...pump. if you were going to run it WOT all the time you would want something that would keep up but in this instance I would say they are wrong. I watch my fuel pressure gauge and it only gets to the minimum recommended psi at wot. AND who does that even once a day or week?
Anyhoo... IF you were to get stage 1s, you would absolutely have to get your truck re-tuned for them. Is it too late to delay the order and consult with people before you chisel stock sticks into stone?
#28
#29
Never get tired of hearing this comment. Now you know where to get all your info with your truck, welcome aboard.. Also, another one here, cancel the stockers and go with a stage 1, its not that much more and you will see a difference like the guys said.
