100hp Injectors - Page 2 - Ford Truck Enthusiasts Forums
100hp Injectors
Old 01-03-2013, 12:42 PM
Yingling256 Yingling256 is offline
Yingling256 is starting off with a positive reputation.
the tranny is stock, never touched it. but my injectors wents out and im looking to gain a little more power while i have it all apart and i figured just putting stage one injectors in it would give me some more power but wasnt sure if i would need to buy anything extra to power the injectors or not... like i said i have a cold air intake exhaust and a chip on it. just looking for a little more power.
Old 01-03-2013, 01:02 PM
i just dont want to put bigger ones in and have to do a bunch of other stuff to it for the truck to run right. i want to go bigger though.
Old 01-03-2013, 01:17 PM
Crewcab Turbo's Avatar
Crewcab Turbo Crewcab Turbo is offline
Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.
Stage 1's sound like what you are looking for. AC 160 injectors with a stock nozzle or 175/146 sounds close to what you describe. Give Swamps a call, and Riffraff a call see what they recomend. There are others out there too. Most likely their recommendations will be similar.
Old 01-03-2013, 01:51 PM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Stock AC 160s, otherwise known as stage 1s. They'll blow your hair back without blowing your wallet out. I suggest new... as opposed to remans. These injectors are already engineered for existing trucks out there with the High Output T444E.
Old 01-03-2013, 01:52 PM
JT250's Avatar
JT250 JT250 is offline
JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.JT250 has a good reputation on FTE.
Quote:
Originally Posted by Crewcab Turbo View Post
Take a look at Swamps diesel. They are the ONLY company that's builds their own injectors and also does their own tuning. I like the idea of no finger pointing between the injector suplyer and the tuning company. Swamps may not be the cheapest but, They have the best warranty you will find.
Actually I beleive Nate at Unlimited Diesel Perfomance has the best warranty at Lifetime.
Also he works very closely with Matt at Gearhead performance for the tuning. Matt has had several trucks in Diesel power lately that he has tuned. (the most of anyone I beleive).
However swamps is great along with all the others. If one was close to you that is who I would go with. I wish I was closer to Matt so I could get live tuned.
Old 01-03-2013, 04:34 PM
KonaGrown's Avatar
KonaGrown KonaGrown is offline
KonaGrown is starting off with a positive reputation.
YingLing, you haven't mentioned if you had any gauges. If you are going to upgrade injectors I HIGHLY recommend that you get a set of gauges. Atleast an EGT gauge.
Old 01-03-2013, 06:10 PM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
I think you need to be the first to go with the 20% over stock injectors you mentioned and then tell us how you like them. They should work with your tuner the way it is till you can get live tuned. Should put you in the same place as the stage one 160 AC's or close. If you go bigger you better have gauges. Let us know what you do please.
Old 01-03-2013, 06:15 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
If you want stock injectors with oversized nozzles those are out there, but they are not super popular.
Jim at Rosewood has the "Budget" stage 2's for $885 which is a 80% over nozzle on the stock AD/AB injector, if that is what you want.
Old 01-04-2013, 01:18 PM
i do have gauges, EGT, Tranny Temp, and Boost gauges. i talked to the guys at riff raff and they said i would have to get a bigger fuel pump for my truck to run right on stage one injectors, so i just ordered stock injectors.
is there anything i can do to my truck to make it run better without paying a fortune?
Old 01-04-2013, 01:34 PM
VegasFordSD's Avatar
VegasFordSD VegasFordSD is offline
VegasFordSD has a great reputation on FTE.VegasFordSD has a great reputation on FTE.VegasFordSD has a great reputation on FTE.VegasFordSD has a great reputation on FTE.VegasFordSD has a great reputation on FTE.
Weird! I'm running Casserly "stage 1" 160cc single shots on stock fuel with absolutely no problems. I know a lot of people running 160's with stock fuel.
Old 01-04-2013, 01:47 PM
JT250's Avatar
Quote:
I'm running 160s on stock ...original...pump. if you were going to run it WOT all the time you would want something that would keep up but in this instance I would say they are wrong. I watch my fuel pressure gauge and it only gets to the minimum recommended psi at wot. AND who does that even once a day or week?
Old 01-04-2013, 01:55 PM
Tugly's Avatar
Clay said that? Whiskey Tango Foxtrot.... Uh... I'm running stage IIs and while the pump is at it's limit, it's doing it. Maybe he found something out about longevity that I don't know.
Anyhoo... IF you were to get stage 1s, you would absolutely have to get your truck re-tuned for them. Is it too late to delay the order and consult with people before you chisel stock sticks into stone?
  #28
Old 01-04-2013, 02:56 PM
I have talked to 5 injector suppliers and all say a stock pump with a regulated return will run all of the stage 2's I have been looking at. I'm verry surprised to hear Clay said that.
  #29
Old 01-04-2013, 03:34 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
okay, thanks guys you helped me out alot! and saved me a bunch of money!!!!
Never get tired of hearing this comment. Now you know where to get all your info with your truck, welcome aboard.. Also, another one here, cancel the stockers and go with a stage 1, its not that much more and you will see a difference like the guys said.
  #30
Old 01-04-2013, 04:47 PM
^ x2. What he said!
Power adders question petekf4qoe 1999 - 2003 7.3L Power Stroke Diesel 18 05-12-2016 10:36 AM
Question about performance upgrades petekf4qoe 1999 - 2003 7.3L Power Stroke Diesel 6 05-11-2016 03:24 PM
97 7.3 Powerstroke turbo diesel more power? kfowler.98 1994.5 - 1997 7.3L Power Stroke Diesel 29 04-28-2015 02:13 AM
2000 excursion 7.3l turbo problem peruexcursion2000 1999 - 2003 7.3L Power Stroke Diesel 10 10-19-2011 05:20 PM
pensacola 70hp injectors with no tuner? 76cougar74100 6.0L Power Stroke Diesel 3 03-29-2010 10:01 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
