Thanks for the reply roger.when i had the fuel presure install under the filter.it was at 32 psi.had my son put it in drive.but when he pressed on the brake.fuel presure drops to 0.then stumles on stuts of.this is frustrating.i wonder is it my computer.
Hey guys have some feed back with my 05 f350.i gave up took it to the dealer.they stated they had to call the ford hot line for this problem.they said i had a loose ground #400 & 401 it was located in the rear.thank you guys for all your support and maybe this can help someone else.
